3406E leaking oil behind fan hub !!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, Sep 9, 2022.
  1. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    Its all good. No matter what gasket is original and have to be replaced. Sucks i know
    spsauerland Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    I found out why the last couple of Cat kits I bought had them. They weren’t Platinum kits. My wrench bender gets some stuff out of Cat under military support and sustainability program numbers.
  4. Slow302
    348
    117
    Jul 12, 2013
    MO
    So after more using $fit loaf oul because front housing leak i took it ti CIT in St Louis that did in frame 2 years ago. They said it needs front housing kit to replace all gaskets and thet kit disnt come with Platinum kit, like i knew so i was ok fak it, i need this oil leak fixed and not worry about it anymore. A few days later they send another email repair estimate. This tme they said it needs upper front housing it self. Boy if i find it is cracked while they were doing in frame 2 years ago when that mechanic was pulling head croiked anf it was stuck, ill go nuts. Ill make them pay for every fricking thing, even shop supply, or i burn place down and be behing bars for rest of my life. So if i dont post anymore, im overthere
  5. Slow302
    348
    117
    Jul 12, 2013
    MO
    They want to replace whole housing because there ia snall gauge where front main seal goes. I show pics to Cat and even they said just sand it, press new seal and keep trucking. Im sure this seal was newer replaced and KW mechanic made those gauges while pulling old seal
  6. IH9300SBA
    IH9300SBA Road Train Member
    2,335
    22,670
    Feb 26, 2021
    How can they gouge it while pulling a seal they didn't replace?
    lester Thanks this.
  7. Slow302
    348
    117
    Jul 12, 2013
    MO
    Since they were replacing evwry swal on front housing they also replacwd front main seal. It came in kit
