3406E misfire that won't go away, even after overhaul
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JCMtrans, Jun 2, 2019.
  1. JCMtrans
    JCMtrans Bobtail Member
    45
    27
    Dec 29, 2016
    Thanks again to EVERYONE who has helped me with your knowledge and expertise over the last few years, especially lately! I posted a while back about a misfire immediately after my out of frame overhaul on this 5EK, which turned out to be a timing calibration issue since the engine was entirely disassembled. SO....started working this new engine right away, hauling heavy loads of rock in and out of Wyoming, and really the engine has ultimately been fine.....even after 15k miles of hauling. The PROBLEM....is that prior to overhauling this engine it has a slight misfire, like one cylinder isn't quite doing its job. It's what led me to overhaul it in the first place, with 1.2million since last being apart. I noticed even after getting the BIG misfire (timing calibration) corrected, it STILL has this miss.....even after breaking it in. Under load in low range, starting out loaded heavy, it is a cab shaker. Here's the breakdown....Idle is glassy smooth in the mornings, when things are cold, but the misfire is worse when under load. When the engine is hot, the misfire is worst at idle to 1300rpm, listening to the exhaust it sounds terrible...an obvious "lope" like a hotrod with a hot cam. However when the engine is hot, it smoothes out under load in the higher gears. I have replaced all sensors on this engine, replaced the injector wire harness (again), the engine wire harness is brand new when I out of framed.
    The only three things I have not replaced: cam sensor, ECM, and camshaft/rockers......although the machine shop looked at these and said they were good, and repolished the cam. The cam did not have any signs of flaking/wear that I could see either.
    1. Can the cam be worn enough to cause a partial miss, without any obvious signs of wear?
    2. Can an ECM cause a single cylinder to partially misfire?
    Cat ET shows it is cylinder 3...it contributes very little but still passes the automated cutout tests. I have replaced the injector in cylinder 3 (3) times. Miss was terrible with two Cat Reman injectors, but finally smoothed out under load when hot with a BRAND NEW cat injector. Like whatever is causing this problem, the NEW injector responded to it under load much better.....I have yet to read or hear about ECM problems causing this...they seem to just cause an engine to die and no start when they do go bad?
    THANK YOU again to anyone willing to chime in on this EXPENSIVE and perplexing issue....
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    While without having the truck to properly diagnose I can say that you should watch just throwing parts at it. I don't like seeing guys throwing good money at bad. Now with the three injectors...did you ever have them tested to see if the remans we're actually bad? Was the head checked during the overhaul? Was the cam checked/replaced during the overhaul? Sorry for the 60 questions, just trying to give you ideas of where to look.
    EverLuc and JCMtrans Thank this.
  4. FlaSwampRat
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Aaaannnnndddd it says you haven't replaced the cam.....I'm retarded......
    Did you have it measured to make sure it doesn't have a smoked lobe?
  5. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Have you ever checked the fuel lines or fuel pressure.?
    There was a guy on here having sorta same symptoms and it ended up the return line to the tanks was plugged up. Couldn't return the fuel, causing overheated fuel staying in head and trapped air also.
    If you have never replaced the cam timing sensor and still running the old style, I'd replace it anyway. The new style is a better sensor, just throw the old one in your tool box. Always good to carry a spare on an E model anyway.
    Wheeljack, JCMtrans, Oxbow and 2 others Thank this.
  6. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    I think I would of replaced the cam since you did a complete overhaul. I mean with 1.2 million miles.
    JCMtrans Thanks this.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,892
    May 31, 2010
    West Harrison, In
    I don't hardly use the automated cylinder test anymore, but run the engine with five injectors cut out running on only one cylinder @ a time. I think you replaced the fuel pressure regulator when had the rough running after overhaul. I would make sure had no air in fuel before replacing hard parts. Engine coolant temp, amb pressure, intake air temp, fuel temp sensor and boost sensor readings all affect fuel timing and delivery so monitor them when engine is running rough. What kind of fuel are you running? I know a guy with a C-15 that swears he can hear a difference in exhaust with the places he buys fuel(bio amount) and fuel temp. Here is cool tool I keep going back in forth over to help diagnose injector issues.
    General Technologies Corp. GTC605 Fuel Injection Analyzer
    Wheeljack, EverLuc, JCMtrans and 3 others Thank this.
  8. JCMtrans
    45
    27
    Dec 29, 2016
    I will have to check with the machine shop to see if they mic'd the cam, they said it was ok, but I wasn't provided any specs as to HOW the cam is "OK"....so that does raise the question about this cam. It had been inframed once before, unknown if the cam was replaced at that time, but I'll just assume it hasn't. That being said, the cam just may well have in the neighborhood of 2.5 million miles on it....since that's what the truck has overall. I'm the 2nd owner, the first owner put 2.2 million on it....although just going off of what the machine shop said, "if it doesn't have obvious wear its good." When you're talking precision and wear, that ultimately doesn't count for much. I mean, eyeballing it? Now that I think about it, it's hard not to just pull the cam and replace it since I've done quite literally everything else to this engine. I've been going back and forth about the cam/ecm and with either getting the rockers re-bushed/re-roller'd or remans, cam/ecm are about the same price when you talk about totality of the job price-wise. It's been a relatively slow start to the year and it's just hard to throw a couple grand at a cam and not have it be the problem. I'm wondering if there is a way to test the ECM or injector pulse just to rule that out? Without losing days of work sending it out to be tested?
  9. JCMtrans
    45
    27
    Dec 29, 2016
    I replaced all the lines on the engine with Cat OEM ones, all fuel/air/coolant, etc along with brand new pump/regulator/primer, I'll check the return line to the tanks, I replaced the fuel return line from the back of the head to the fuel block, but not the line to the tanks. I am thinking how silly it is not to just replace the cam sensor, considering how all other sensors are new. I'll replace it this next weekend or if a work day gets over early. I can check with Cat Tech on the phone but do you know if I have to recalibrate if I replace the sensor?
  10. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Do you not know anyone with a E you can borrow there ecm for a day to test.??
    As far as the cam goes, you could just put a dial indicator on each rocker and measure lift . Im guessing with that kind of mileage the cam has been replaced already if not a couple times. If it visually looks nice I'm sure it's fine. Lobes dont go flat and still look good.
    spsauerland and JCMtrans Thank this.
  11. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Yes check both suction for air on the feed and flow on the return to the tanks.
    No need to recalibrate with just a sensor change out.
