3406e oil in fuel tank
Discussion in 'Ask An Owner Operator' started by W9in’, Jun 5, 2021.
  1. W9in’
    W9in’ Bobtail Member
    15
    11
    Sep 29, 2019
    The mechanic who has my truck said he sees oil in my fuel tank and wants to pull the head but I just got it back from peterbilt and they said my motor is within spec minus injector cups.
    motor is a 98 1lw 3406e
    do you have to remove the head to replace the injector cup?
  3. Ridgeline
    20,742
    101,059
    Never heard oil in fuel seeing fuel is an oil.
    no, you don’t pull the head.
    here, this is the best video how to change the injector cups on a 3406.
    sorry it is in Spanish.
    W9in’ Thanks this.
  4. Big Road Skateboard
    4,396
    20,933
    May 2, 2021
    Not on that CAT. Did the fuel analysis come back as oil, or combustion chamber gasses?
    Combustion chamber gasses are often mistaken as oil because it turns the fuel black. Also, many misdiagnose combustion chamber gasses as injector o-ring or injector cup failure, when it's actually an injector not sealing off after injection, allowing gasses into the fuel.
    Jbuckner, slow.rider and W9in’ Thank this.
  5. Spyro2112
    Spyro2112 Medium Load Member
    567
    381
    Mar 17, 2018
    Probably algae, no oil in coolant? Your good sea foam new filter
    dunchues, slow.rider and W9in’ Thank this.
  6. Spyro2112
    567
    381
    Mar 17, 2018
    2nd thought welcome to bio diesel
    Roger McG and W9in’ Thank this.
  7. W9in’
    15
    11
    Sep 29, 2019
    No oil in coolant at all
  8. W9in’
    15
    11
    Sep 29, 2019
    Oil analysis was showing it was good but this was 5k miles ago. I was thinking that as well. It does sputter sometimes if I blurt the throttle and it’ll throw some white smoke then clears up
  9. W9in’
    15
    11
    Sep 29, 2019
    I haven’t either. I think he doesn’t know much about motors or he’s trying to get over on me because he’s adamant about having to pull the head and replace or machine
    slow.rider Thanks this.
  10. W9in’
    15
    11
    Sep 29, 2019
    Thank you I figured you don’t have to remove the head. He keeps telling me he has to remove it
  11. ready2truck
    ready2truck Medium Load Member
    301
    351
    Oct 27, 2020
    Just pay a little more and go to cat.
