3406E power problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by logtrucker25, Apr 27, 2011.
  1. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    Hey all still trying to figure out why I have low boost on a 5ek factory 475. I've had the turbo checked, put new cac boots on, tried pinching the wastegate, changed the boost sensor and changed the fuel filters. It will only get 18 lbs of boost in a pull and is very sluggish but the weird thing is if you come to a stop after driving for a while an take off again it will get its normal 25 pounds of boost but only for 30 seconds or so. Seems like maybe not enough fuel? it runs perfectly smooth an never smokes any color anytime an throws no codes. Any help would be appreciated, thanks
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    maybe the waste gate is set to light opening up to fast or bad gauge maybe
  4. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    Can be a crack in the inter-cooler.
    Only opens up when it heats up due to absorbing heat from the hot compressed air.
    Once flow stops the crack seals up again till it heats up again giving you the 30 seconds with out boost leakage.
    logtrucker25 Thanks this.
  5. dicky
    dicky Bobtail Member
    31
    8
    Aug 16, 2008
    st.paul , mn.
    Do you have a fuel pressure gauge in the final filter housing ? , if not put a gauge on to monitor it while you are running it , see what changes when you have boost and when you don't have boost . You said it's a 5EK so I'm guessing its in an older tractor. I would be leaning towards swollen fuel lines as being your problem.
  6. logtrucker25
    70
    9
    Jul 27, 2009
    northern CA
    Thanks for the help so far I'll have to pressure check the CAC. today i drove with a fuel pressure guage hooked up an it stayed at 60 the whole time no matter what boost. (50 at idle) is that kinda low??? I"ve replaced all the fuel lines except the small one that goes from one side of motor to other
    Swamp molly Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    7,816
    6,270
    Feb 4, 2009
    Is your CAC plugged by any chance? Check for dirt or lots of bugs. I may just need a good cleaning.
  8. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    fuel pressure is kinda low for a 3406e
  9. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    mine runs around 80 at idle and 110 down the road if that help's
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    emodel cat doesnt have an intercooler just a cac.
  11. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Charge air cooler and air to air intercooler are interchangeable terms I believe...Mack was one of the first to use an air to air... that's what they call 'em around here to this day...
