3406E sensors
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Grainfarmer, Feb 7, 2018.
  1. Grainfarmer
    Grainfarmer Bobtail Member
    46
    8
    Apr 25, 2017
    Hey guys. I have my buddies 1996 379 in the shop and I was going to look at fixing a few gauges that don't work (fuel level, oil temp, pryo) I was trying to locate the oil temp sensor and I can't seem to find it. Nothing in bottom of pan. Have power going to the gauge on the white wires the gauge doesn't move at all.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It won't have a cat oem temp sensor.
    It should have a Peterbuilt installed sensor in the pan. If the wires are there someone took it out.
    Oxbow and pushbroom Thank this.
  4. Grainfarmer
    46
    8
    Apr 25, 2017
    Ok. There is no sensor so I will have to wire one in than.
    Oxbow Thanks this.
  5. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Yeah peterbilt used a 1 wire sensor engine oil temp sensor on a cat engine that vintage should have been low in the pan on the driver side
    swaan Thanks this.
  6. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    Peterbilt was good about there wiring harness' if there is a gauge in the dash then the wiring harness for the sensor should be in the engine harness. On my 1993 379 with a Cat 3406C the wire # for my oil temp sensor is 282 on the engine harness
    Oxbow and swaan Thank this.
  7. Grainfarmer
    46
    8
    Apr 25, 2017
    I got a wiring diagram. From the cab to the engine harness it isn't labeled I think I found it, sensor will be here tomorrow. I think I found the wire so tomorrow ill see if it's the right one
    Oxbow and Roger McG Thank this.
  8. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    There should be a small tin band around that wire close to the plug end with stamped #'s on it.
    Oxbow Thanks this.
  9. Grainfarmer
    46
    8
    Apr 25, 2017
    I think someone removed it and took out the sensor cause the wire has been used and has a joint on it. Thanks for your help!
    Oxbow Thanks this.
  10. Oxbow
    Oxbow Road Train Member
    12,836
    133,002
    Nov 24, 2015
    You can test the wire by grounding it out and looking to see if it pegs the gauge. Might pay to check with a test light first to make sure it isn't another wire that is hot.
    wore out, SAR and spsauerland Thank this.
