3406e tach wont work
Discussion in 'Kenworth Forum' started by towtech, Dec 13, 2013.
  1. towtech
    towtech Bobtail Member
    Hi I'm new to this forum so thanks for any help up front. I'm working on a 97 w900 with 3406e. The tach has been intermittent since having the truck lately it hasn't been working much at all. I have installed the tach into other trucks and it works and have tried other tachs in this one and they don't work. I have ohm tested the wires from ecm to tach and they are good there is 12 volts and ground at the tach. I can get an rpm reading using my scan tool. There is no other problems with the truck. There is no tach sensor on the bell housing that I could find. My understanding is the cam sensors gets the rpm reading. I have called kenworth and made sure the switches on the tach are set right. The cat dealer has told me they need to scan it with their cat et. I am wondering if there are any other tests I can do before going to them. Again thank you.
  3. Flightline
    Flightline Road Train Member
    2,345
    1,166
    Oct 1, 2011
    Almost There
    I had the same problem and it was a bad connection on the back of the tach. I used a wire tie to hold it tight for approx. a year. It would cut out sometimes. Finally I purchased a digital tach. and been great since. Digital tach was lot cheaper than new Peterbilt tach. approx. 350$
  4. towtech
    I have tried wiggling wires and plugs to make it work and no luck. It seems to work on its own for no reason.
  5. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Speed sensor would be my guess.....
