3406E temp sender
Discussion in 'Trucks [ Eighteen Wheelers ]' started by billm89, Oct 20, 2014.
  1. billm89
    billm89 Bobtail Member
    39
    19
    Jul 20, 2011
    Mass.
    Does anyone know where the engine coolant temperature sender for the gauge is located on an 1998 early 3406E Cat with the 40 pin ECM? There is nothing by the thermostat housing except a hose that goes up to the surge tank. I'm looking at one on the back of the head by the firewall with two spade terminals, but I'm not sure it's the one. I'm hoping to get some time to trace wires this week to help figure it out. The gauge worked until last week, but now stays pegged on the low side. Thanks for any help.
  3. mtoo
    mtoo Road Train Member
    1,936
    4,511
    Jan 15, 2011
    Retired on bended knee
    It should be on the thermostat housing, If it's like a 3406C it will be on top. Right behind the A/C compressor.
    billm89 Thanks this.
  4. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    it is a PITA to get at.just like above post said,but you have to look close to see it buried behind a/c compressor.good luck.
  5. billm89
    39
    19
    Jul 20, 2011
    Mass.
    Thank you guys, I'll look closer tomorrow.
  6. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    On mine 98 3406E 40 pin the gauge is mechanical. From the gauge the capillary tubing going through the firewall to the front top of the cylinder head. It is very close where a fuel line connects to the cylinder head. Yours may be different i.e. electrical....
  7. billm89
    39
    19
    Jul 20, 2011
    Mass.
    Mine is definitely electrical, I'm familiar with the capillary ones from the old race car days. Thanks for the input!
