3406E vibration and very slight mis at higher rpm
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Northwinds1, Mar 11, 2013.
  1. Northwinds1
    Northwinds1 Bobtail Member
    41
    5
    Mar 11, 2013
    Maybe some of you cat guys can help me out... here is the story. Family member just bought a 2000 classic with a 2WS cat 3406E. Has 820k miles. Truck was serviced and takin care of regularly, coolant system is clean and internals clean. It was traded in because previous owner thought engine needed rebuild. We pulled valve covers after getting it and found a roken #4 injector spring. I replaced the #4 injector with new cat injector and did a fine tuned overhead adj. On it and changed trim code. Truck runs much better now and has power back but still noticing a vibration (ruled clutch out) and when running rpm up at 1400-1500 rpm there are a few slight hickups. Could this be from a bad injector harness? (13yrs old) i checked over the fuel system and changed filters. Also performed cutout test and keeps saying #2 fails and to check connections on injector. Which i did and nuts are tight. It runs good otherwise, no smoke at all and nothing has been touched besides overheads, still paint on all engine bolts. Is it common for these to have a dampner create a bad vibration thru cab?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    if #2 failed thats it! one of two things #2 injector or wire harness. it cheaper to change the internal harness than an injector. or swap #2 with #1 injector and see if it still shows bad. then you will know it's the injector.
    Buckshot7cz and SHC Thank this.
  4. Northwinds1
    41
    5
    Mar 11, 2013
    Thanks, I will try the injector harness first. Are injector harness problems somewhat common on the 3406E? I know the detroit 60 engines had some problems with oil wicking and ive done those before. Just curious if this is a rare occurrence?
  5. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    yes with age. the hot oil makes them brittle and prone to breaking especialy if you have disturbed them.
  6. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    Anytime CAT ET fails an injector cut out test..........the work begins in diagnosing the problem. CAT has updated the wiring harnesses with heavier gauge wire and insulation to the injectors. It wouldn't hurt to update the harnesses. If it fails a cut out test after that then swap injectors to see that it follows the injector, if it does than you will need a new injector
  7. Northwinds1
    41
    5
    Mar 11, 2013
    Well after replacing the injector harness and changing out another bad injector i got the engine running correctly. Now i need to figure out what is up with this vibration... it starts at about 1100rpm up to1500 rpm. Engine sounds smooth and no smoke or anything odd. The clutch was replaced a few months ago. Engine mounts are old but seem ok yet. Should i try a new dampener? It idles very smooth also.
  8. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    next time when idling at 1100 to 1500 rpm push the clutch in and see if vibration changes. all engines have a vibration of some sort at certain rpm's, damper pully might be a good idea if it has alot of miles. it's cheap insurance.
  9. Northwinds1
    41
    5
    Mar 11, 2013
    Yes i did try pushing clutch in with truck sitting still idling also and no change. Its a real mirror shaker at 1350the rpm. I picked up a balancer so i will try that next. It seems to be running healthy and has good power so i wouldnt think it would be an internal problem would it? It has a dyno run scheduled today also so maybe that will help figure something out.
  10. Northwinds1
    41
    5
    Mar 11, 2013
    Truck ran great on the dyno. Rated 500hp. It ran 415 to the ground and blowby was 0.9 peterbilt guys said he would look into the clutch making the vibration. Is it possible to pull the clutch/flywheel and have it balanced together someplace? If i need to.
  11. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    I got the same problem on mine. But #6 injector was bad (found on dyno) cause it passed the cut out test. So replaced #6 injector and started right up fine and smooth idle then a day later had miss again from 1400 to 1700 during acceleration can it be the wiring harness on mine too mine is 11yrsld thx
