3406e
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gear head, Nov 29, 2012.
  1. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    What is the engine serial of the 3406e marine engine? Also which engine serials did this engine have with the 40 pin ecms?
  3. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    91
    Feb 18, 2010
    Siler City, NC
    9WR is the prefix for the marine 3406E. All were 40 pin
    Gear head Thanks this.
  4. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Thanks but how many serials did the 3406e engines have and what are they. I know they had 1lw 5ek and 2ws was the 1mm and 5ds a 40 pin ecm also?
  5. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    GH
    the 2WS/1MM are 70 pin :biggrin_25514:
  6. CatPowerC15
    347
    91
    Feb 18, 2010
    Siler City, NC
    1MM was 70 pin, 5DS was 40.
    5EK, 6TS were all 40.
  7. Diesel Dave
    9,418
    30,746
    Jan 20, 2010
    Hesperia, Ca.
    Mine was a 5EK 40 pin and had a 5DS file put in.
  8. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    I know the older c-12 motors had 40 pin also is it the same ecm? If so then you can flash it so it could be used on 3406. The 3176 also?
  9. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    6NZ --last of the pre-emission C15
    7CZ --last of the C16 (pre-emission then discontinued)
    MBN ---bridge motor...single turbo
    BXS,MXS,NXS....twin turbo ashurt(accert)
    70 pins are serial numbers 2WS, 1MM, 6NZ, 7CZ, and MBN. "pre-emmision", not NOX. The early 40 pin were pre low NOX.
    Professor Haney can rattle off dates,files,serial #'s. etc while he is sleeping...:biggrin_25514:
  10. CatPowerC15
    347
    91
    Feb 18, 2010
    Siler City, NC
    The 3176 ECM will not take a 3406E file...it has no provision for cylinder cutout, among other things.
  11. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    As to how many and what the serial number prefixes are for the 3406E..........there are too many to list when you consider the industrial, mining, truck, generator, machine, and marine engines. They are used in many different variations and power ratings depending on the application and can have either 40 or 70 pin ECMs.
