34hour restart understanding
Discussion in 'Questions From New Drivers' started by Suzi, Jan 28, 2014.
  1. Suzi
    Suzi Bobtail Member
    Minnesota
    Work 60/7.
    Week of 1/20/14 went over hours - 60.25. The .25 was done doing yard work.
    Had 34hrs off including two 1-5am rests.
    Can I restart my week at fresh 60/7?
  3. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Multiple posts
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    You are all good with going over hours as long as you do not drive beyond the 60th hour. You could rebuild an engine, call it all on duty, claim 100 hours in a week and you'd be cool, so long as you didn't drive.
    Yes your restart is good as long as you didn't have one within the last week.
    Simple, isn't it?
    lol ....
  5. d o g
    d o g Trucker Forum STAFF Staff Member
    24,536
    53,657
    Sep 20, 2010
    Texas
    When you're notified that a post needs to be approved by a moderator, it doesn't do any good to continue submitting it.
  6. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    The thing went so fast I didn't know WHAT was being said or going on. Weirdest thing I ever saw.
    Now; as to the OP...if you clock in and out at the same location daily (which most do in 60/7 short haul), you are given one 16 hour day to use if need be.
  7. Powder Joints
    7,687
    7,781
    Sep 25, 2007
    Rosamond, SoCal
    When did you take your last reset. You need a full 7 days between them to the minute.
  8. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Correct, but a bit confusing!
    From the time your last reset BEGAN, go forward 168 hours (7 days). If your last reset started at 1700 hrs on Friday, the next Friday at 1700 (or later) you can begin your 34 restart.
    CondoCruiser Thanks this.
  9. Powder Joints
    7,687
    7,781
    Sep 25, 2007
    Rosamond, SoCal
    The other note here Hours of Service only limit your driving hours to a max of 60/70/ 11 out of 14. You can work as many as you like without being in violation.
    Worked hour still count against the 60/70/14 hour rules, i just counts against you available drive time.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Otter said it well. You need a full 168 hours between resets. If you are off Friday afternoon and don't return work until Monday morning there is no reason this can't be easily accomplished. Even if you don't do a reset you will gain a couple days back and still good to go working similar hours daily as your recap rolls.
    The 16 hour rule only applies to non-CDL drivers using the 150 mile rule.
    Considering she is not a short haul driver which she doesn't say. I would assume those running under a M-F operation might be local. But all other CDL operations outside the 100 mile circle you are 100% correct.
    otherhalftw Thanks this.
  11. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Huh?:biggrin_2556:
