3zj with 160-1130 pistons questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambino1994, Sep 10, 2019.
  1. Gambino1994
    Gambino1994 Light Load Member
    187
    102
    Jan 22, 2009
    causing a situation
    Is the proper connecting rod needed to use the 160-1130 14.5/1 aluminum piston a different size wrist pin than my current rod? Right now I’m running the 101-0016 16.4 pistons. Would I need a E model rod or a different one than that even?
  3. wore out
    wore out Numbered Classic
    16,190
    196,288
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The 160-1131 piston uses the small pin with wide bearing rod. The E uses the big pin
    5YG00466 is a good engine serial number that used that piston factory. Should be able to use it to get a good number.
    Now 9Y6408 will be cast on side of all wide bearing rods. Both big and little pin. I have been through this
    Wheeljack, Oxbow, spsauerland and 3 others Thank this.
  4. Gambino1994
    187
    102
    Jan 22, 2009
    causing a situation
    Ok thanks you kinda read my mind lol, so when I try to find a set of rods I gotta look for the same casting number rod I have now, just with a smaller wrist pin diameter?
  5. wore out
    16,190
    196,288
    Jun 5, 2013
    Yes. Call cat and use my serial number to get a good part number
  6. wore out
    16,190
    196,288
    Jun 5, 2013
    I can remember the last digit on the re man part numbers is 1 different from small to big pin rods. It will be in blue near the cap
    Wheeljack, Oxbow, cke and 1 other person Thank this.
  7. Gambino1994
    187
    102
    Jan 22, 2009
    causing a situation
    Excellent info, and this piston is compatible with or8785’s and my stock piston oilers?
  8. wore out
    16,190
    196,288
    Jun 5, 2013
    No go to the double oiler and put the E model spring in your pump. Use the serial number I gave you for Oilers. As well as 3425 nozzles with a 177148 windmill it will suit you I assure you
  9. wore out
    16,190
    196,288
    Jun 5, 2013
    Serial number I gave you is a 460hp peec
    Wheeljack, Oxbow and Gambino1994 Thank this.
