40/45 ft trailer to 53ft trailer
Discussion in 'Questions From New Drivers' started by Lonewolf2000, Jan 25, 2018.
  1. Lonewolf2000
    Lonewolf2000 Medium Load Member
    310
    323
    Nov 5, 2017
    New York
    Just curious besides having to turn wider is it any more difficult to drive a 53 than a 40 or 45 footer?. I have trained on both a 40 and 45 footer, predominantly the 45.
  3. Moose1958
    Moose1958 Road Train Member
    15,169
    33,410
    Dec 17, 2010
    Williesburg, Virignia
    I might be a minority of one, but I found backing a 53 to be much easier then the shorter trailers.
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Watch your tail swing. There isn't much, but if you get right up against a line of cars before turning then turn sharply you can hit those cars.
  5. KillingTime
    KillingTime Road Train Member
    3,865
    61,880
    Mar 26, 2016
    Rockland, Maine
    Pour on the horror stories, boys!
    It's 8-13'...... jeez, just adjust for that space. Doesn't require you to break out a tape-measure. Any doubts: lift your ### off the seat cushion and down the steps to look. **Don't forget to set those brakes!**
    Kyle G. Thanks this.
  6. Kyle G.
    Kyle G. Road Train Member
    3,851
    20,212
    Jan 23, 2016
    Eastern Iowa
    Ditto that. The hardest trailer I ever had to back is my leaf sweeper for the riding lawn mower. Took several “pull ups,” lol.
    Aamcotrans, jammer910Z and Rickp Thank this.
  7. REALITY098765
    REALITY098765 Road Train Member
    1,489
    1,321
    Sep 17, 2017
    Don't think of it the length of the trailer it's the length of the bridge [king pin to trailer axles] that matters and 1 of the reason's for 'bridge' laws.
    There's more to it but that's the jist of it.
    BillStep Thanks this.
  8. Lonewolf2000
    310
    323
    Nov 5, 2017
    New York
    I agree shorter trailers such as the 26 I started on are a PITA to back, back the 40/45 easy.
  9. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    I got into an argument not long ago in one of these threads with someone about backing , and trailer length.
    It's my position, too, that the shorter the trailer in relation to the length of the towing vehicle the more difficult the backing.
    It's simple physics with the arc and radius that the longer trailer means easier backs because of slighter adjustments needed at the wheel to gain correction.
    Other guy argued a day cab and a 28ft pup was easier.
    It may go into easier places... but the act of backing is more delicate.
    I finally had to just give up.
    Texas_hwy_287 Thanks this.
  10. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    With 53's, having the tandems slid all the way back is very non-typical so they are not too much longer. But as was mentioned, "tail-swing" comes into play in tight situations, both turning and backing. So be aware of this but don't let the idea "cripple" your thought processes in normal situations.
    jammer910Z Thanks this.
  11. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    If you have a day cab. Even a 20ft can is easy to back. But throw in a 265" truck and 20ft can. Well that can is going to whip you. Used to pull ( Back in the day) 36,38,40,42' trailer. Then we got 45' trailers. Then 48, then 53's and you get the ideal.
    Well in a week I might pull a 36ft Tanker, 40ft tanker then a 42 ft van. Then a 45 ft Reefer all in the same week. No issue with the old cabovers.
    Next year same trailers, but a 244" hood sticking out there. Throw in all those trailers. And the 53 was my favorite one to pull when we got those. Easy to back, with the tandems forward. But tail swing had to be watched.
    Just watch what your doing. And you will not even know what size trailer is back there in a few days. That 53ft will not react as fast as the shorter trailer will.
    Sorry for the book. For some reason I ramble these days. May be getting old.....
