Debating between a tri flatdeck or a super b flat to run western provinces for the next couple months here. I have ran super b 63,500kg tankers in Alberta and Sask for years with my Peterbilt with dsp41 rears with no issues but that's pretty flat ground.
My thought is I should go with a tri if I want to haul mountains, guessing my 40k rears would just run too hot pulling the mountains with super b weights but I wanted to see if anyone who's done it can chime in?
Thanks everyone.
40k rears, Super B and BC mountains?
Discussion in 'Canadian Truckers Forum' started by dustinbrock, Apr 24, 2020.
I've never had an axle issue running anywhere; oilfield/construction/pipeline (off-road, soft ground/mud), or coast-to-coast (Vancouver and Prince Rupert to NB), down to Houston, 120* in Arizona, etc. Lots of both, tri and Super-B. Lots of OS. I think they were all Super 40s, which I think are different, but I wouldn't hesitate. I'm sure you know; easy on the throttle, especially when loaded, uphill, low RPM, yadda, yadda, yadda...
I did blow up an 18-speed though.Cat sdp, AModelCat and dustinbrock Thank this. -
I'm always confused with 40 vs super 40. I want to say super 40s are a 40k housing with beefier internals.
I seem to recall @uncleal13 gave some good advice about this exact question a while back.uncleal13 and dustinbrock Thank this. -
So the Super 40 is built like a 46 but weighs less?
The only rears I’m familiar with is the regular 40 and 46.
Just a few weeks ago, I learned there are 52,000 rears under some trucks. -
Does the super 40 have the same amount of oil as the 46...?
Red is Super 40 Blue is 46k rear.
beastr123 Thanks this. -
Later I switched to super B hopper bottom on the prairies. In the summer they would still push 300 degrees on the tough pulls. After two years the bearings gave out in the front diff.
The last couple of trucks had 46,000 lbs rears, temperatures rarely break 200 degrees. That would only happen on the hottest summer days, 170 being normal.3noses, Phantom Trucker, Cat sdp and 2 others Thank this. -
