40k to 46k upgrade
Discussion in 'Flatbed Trucking Forum' started by caftransport, Dec 28, 2013.
  1. caftransport
    caftransport Light Load Member
    68
    14
    Mar 18, 2013
    How much is involved with increasing drive axles to 46k. Or is it feasible to pull a 35 ton rgn or tridem stepdeck with 40k axles?
  3. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Will you be allowed or need to have 46K on your drives? Different states have different laws. Here NY will let you go to 107,000lbs on 6 axles, 58,000 on a tri. So if you are 12,000 front, 40,000 drives, 58,000 trailer tri thats 110,000lbs. No need to increase drives.
    not4hire Thanks this.
  4. caftransport
    68
    14
    Mar 18, 2013
    What I was worrying about was being over on the drives if I had a heavy load but would be fine with 46k, particularly with a tridem stepdeck or rgn.
  5. wore out
    wore out Numbered Classic
    15,709
    189,880
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A swap like that is never as easy as it seems. Usually it looks like every thing will go right in then these little differences start a rising. I would want the whole donor truck if possible. You may know but be sure to put a bolt and nut in any left over holes in the frame or weld them up and grind down.
  6. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Would you not need some sort of certification from the OEM that the truck is now rated for the new weight? Also consider other things like U-joints and frame ratings. The diffs may not be the lowest common denominator.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Yes, anytime that you increase a trucks weight capacity you need to get a new sticker or some sort of certification to make it legal in the eyes of the DOT. I am not sure how these are obtained, when I started pricing everything to make my other truck capable of hauling more weight it was cheaper to just go buy a different one.
    milskired Thanks this.
  8. caftransport
    68
    14
    Mar 18, 2013
    Perhaps a simple DOT inspection would do. I ask this because I see many trucks that have all the features I want except 46k axles. I was hoping it would a simple upgrade like different airbags or simple components swap seeing it's only a 3k increase.
  9. TripleSix
    128,540
    Just a suggestion...if you're going to go to the expense of putting 46k rears under your rig, the only thing I could see that would make it worth it is if the diffs had lockers. Yes, 46k is stronger, but for OSOW purposes, some states are going to give you the same restrictions as to how much weight you can have on the drives.
    Quite a few of the Landstar and Daily drivers pull the 2+3+2 trailers with 40 k open diff drives.
    Cetane+ Thanks this.
  10. CL10473
    CL10473 Light Load Member
    58
    6
    Jan 19, 2007
    NY
    Realistically, depending on the truck you can buy a 46k cutoff. If your running a Pete with an Air Leaf, the Air Trac (44k/46K) should be a straight bolt on. As far as re-certifying the weight of the tractor that's can be done by any dealer and most of the bigger truck repair shops. Its verifying the upgrades.
  11. KinkadeIN
    KinkadeIN Bobtail Member
    34
    6
    Dec 26, 2013
    Griffith, IN
    If you have the space wouldn't it be cheaper and less of a headache to install a drop axle? No need to re-certify, no worrying about matching up gear, axle lifts when not needed.
