435 5EK
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TheTrashMan, Apr 23, 2016.
  1. TheTrashMan
    TheTrashMan Bobtail Member
    44
    Jul 28, 2012
    Hello I bought a motor that is originally a 435 and it has a 550 hp file in it (1469216). What needs to be changed to make this run like a true 550? It currently blows a steady stream of black smoke when you're full throttle. Turbo ? There is no boost leaks, 5232 injectors codes and fls / fts 0/0 .
  3. flat top
    flat top Bobtail Member
    44
    25
    Jan 28, 2010
    Colby Ks
    I'd guess you'd need a different turbo, and injectors. Sounds like it isn't getting enough air. Also set the injector codes according to what is printed on them. Setting them all the same isn't doing you/them any good.
    lester Thanks this.
  4. TheTrashMan
    44
    Jul 28, 2012
    Your guess is wrong it uses the same injectors Asa 1lw
  5. Cat sdp
    Cat sdp . .
    20,892
    72,373
    Apr 8, 2012
    Orion's Belt
    First Most gurus say not to run same #s across the board .
    Second if you have aluminum pistons in that thing you aren't going to be a happy camper.......
  6. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Wrong, 5EK 550hp engines do not run the same injector as the lower HP engines. They run a 211-3024 or some older variation where the lower HP engines run a 211-3023 size injector.
    Same goes for the 6TS except the bigger injector starts at 475HP and up.
    So if that 550 file originally came in one of those it is not running right. Just go to a 600 file and be done with it.
  7. TheTrashMan
    44
    Jul 28, 2012
    And a bigger turbo ?
  8. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    It wouldn't be a bad idea to upgrade, the one you have now would suffice for a little bit as long as the wastegate is still working and hooked up.
  9. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    A good upgrade would be the Borg Warner 1496 988 0000
