445 Mp8 Mdrive and 3.08 rears
Discussion in 'Mack Forum' started by Mattmanstroked, Feb 6, 2021.
  1. Mattmanstroked
    Mattmanstroked Light Load Member
    149
    202
    Nov 24, 2019
    How is a 445 with Mdrive and 3.08 gears going to pull?
    I have a 450hp Cummins with 13 speed and 3.36 gears. It needs some 3.55 gears to pull more to my liking.
    Would I be disappointed with the 3.08 ratio? Have seen some trucks with a 2.64 and Mdrive.
    Side note. Does all the Anthem trucks come with a Mdrive?
    Trucking Jobs in 30 seconds
  3. Truckwork2461
    Truckwork2461 Bobtail Member
    36
    12
    Feb 10, 2021
    Anthems can be customized to come with an Allison or Eaton trans. Mdrive is the base choice.
    Mattmanstroked Thanks this.
  4. sebas9558
    sebas9558 Bobtail Member
    27
    59
    Sep 28, 2018
    Colombia
    It depends on which 445HP engine and program you will have. The 445 turbo compound (MP8HE SE.) should pull well with the 2.64 as it puts all of its torque from 1000 RPM and has 1860lbft of torque, but other specs like the MP8 MaxiCruise/EconoCruise/Maxidyne will require higher value rear ends because they just put the torque from 1200 RPM to 1400 RPM and can have anything between 1560 to 1860 lbft of torque, depending on the program you select. Above 1400 RPM all 445's should pull the same.
    Without knowing the rest of your specs, if you want full pulling capacity without excessive fuel consumption, you should spec the truck to cruise between 1300 and 1400 RPM, anything above that will waste fuel; And if you are too concerned about pulling capacity, you may want to get the 505Hp with 1860lbft engine instead of the 445Hp. Also, if you want, you can spec the truck with any Eaton Auto or Manual and even with a Mack Maxitorque manual, but in the field of automated transmissions, the Mdrive should be superior to the Eaton.
    *Note: Without Knowing which ISX 450 you had, is difficult to know why you feel it to be so guttless, as it could be spec with 1450 to 1650 lbft of torque (Or even up to 1750 lbft in the Smart torque versions.)
  5. Mattmanstroked
    149
    202
    Nov 24, 2019
    Have a 2350 at 450hp and 1650 torque. It pulls just not hard enough for me. Had this truck for 180k. Pulled 95k gross with it. Don't get me wrong it gets the job done. Think 355 gears would be way better, but not looking to regear this one. Looking to get a newer truck with less miles.
  6. Echo5kilo
    Echo5kilo Bobtail Member
    35
    30
    Sep 8, 2019
    If it was me. I'd look at the speccs that Joel Morrow of Ploger transportation. The Turbo Compounding engine. Along with a super Overdrive setup they are running. 13-14 speed transmission with crawler gears. You can run high rear axle ratios like 2.05 with the 14 speed. You can run highway speeds in direct and overdrive. But you get the good pulling with the crawler transmission. It's a win-win.
    I have a VNL740 with the Volvo downsped version. D13 455hp TC, 2.47 rears and 12spd I-shift. The setup is pretty legit. Pulling tanker 79k all the time. It pulls way down low. 1,850 at 800rpm up to 1,400rpm. I imagine the 13-14 spd setup is much better.
    I'd get on Volvo truck masters on Facebook. Joel Morrow posts on there all the time. He posts a lot there.
    sebas9558 and Mattmanstroked Thank this.
  • Draft saved Draft deleted
