48' stepdeck trailer question
Discussion in 'Flatbed Trucking Forum' started by 57ringo, Dec 12, 2013.
  1. 57ringo
    57ringo Bobtail Member
    26
    Dec 21, 2008
    Emporia, ks
    I'm looking for a 48' stepdeck to haul big square hay and maybe my machinery sometimes. I've found a 2005 Transcraft Eagle combo and a 2006 Great Dane Combo set up about the same..aluminum wheels, boxes & dump valves. The transcraft is supposed to be an 11' top deck but I talked to Transcraft and they said they all were about 10'6". The Great Dane is supposed to be a 10' top deck according to the owner. I've also seen a couple 1999 Doonan all steel trailers but the rear wheels set a bit farther under the trailer than these do & I want to put a dovetail with fold over ramps in it so I don't like that idea. I also found a pretty good 1996 Trail King all steel but it's pretty bare on options and he wants about as much for it as the others. What are your thoughts on these trailers? I can buy the newer trailer for close to the same money as the older ones.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    40ft lower deck is a must to be of any real use.
  4. 57ringo
    26
    Dec 21, 2008
    Emporia, ks
    I will put a 5' beavertail & fold over ramps on whatever I get
  5. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I own a Great Dane AND a Transcraft stepdeck, mine are 53', but I can tell you given the choice I would prefer the Great Dane if all things were otherwise equal.
  6. 57ringo
    26
    Dec 21, 2008
    Emporia, ks
  7. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
  8. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    I have 38' bottom, 10' top deck and not an issue. Fontain trailer and love it because so light. Only weighs in at 10,400. I think for a step that is light.
    Though wish I had container locks.
  9. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    Honestly, after having been with a company that hauled a fair bit of containers on step decks, I almost wish our trailers didn't. They take out so much securement area that it makes hauling regular freight somewhat more difficult. Of course, I'm kind of OCD when it comes to running my straps/chains right to where I want them, the way I want them, so that might not be as big of an issue for you. What really cracked me up was the main customer we hailed the containers for wanted the cans all the way to the back since their dock plate wasn't long enough to reach inside if the can was on the pin locks, so we rarely used them anyway. :)
  10. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    It sounds like someone didn't spec the proper trailer or manufacturer.
  11. 57ringo
    26
    Dec 21, 2008
    Emporia, ks
    Cetane+, every load of big squares I've loaded for guys on a step deck needed a load leveler a foot or two behind the neck so I can set two big squares on the top deck and have some support under it because u have to let them hang over each end some and the aluminum ramps can be used as load levelers too.
