49", 54", 60" spacings on a tridem
Discussion in 'Heavy Haul Trucking Forum' started by Sumothertrucker, Jan 26, 2020.
  1. Sumothertrucker
    Sumothertrucker Light Load Member
    92
    16
    Jan 10, 2011
    I c corn
    What is the advantage of a greater axle spacing on a tridem? I assume it's more weight per axle? If so, where can I find a breakdown for the spacings on a state by state basis? I currently run a 3 axle trailer with 49" axle spacing but am looking to upgrade and keep the biggest well possible. 54" and 60" axle spacing reduce the well size obviously.
  3. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    every state will be different, but once you get to 60", you can run 43,500 legally in every state, and 60k permitting.
    Sumothertrucker Thanks this.
  4. Sumothertrucker
    92
    16
    Jan 10, 2011
    I c corn
    Any idea where I can find a break down of all states axle spacings? I've been able to permit up to 60k on my tri with 49" spacing from OH to NE and MN to OK without a problem. Would just like to know where I can't go before I find out the hard way.
  5. RollinThunderVet
    717
    970
    easiest place? one of the paper maps at the truck stop. it in the front sections
  6. Rontonio
    Rontonio Road Train Member
    6,439
    47,385
    Aug 9, 2009
    You can check with each state’s website for the actual answer. - barring that - you can go use a reference like the SCRA permit manual that will list the requirements on a state by state basis. I know that you are likely to not get 60k in OR and WA.
    cke and SAR Thank this.
