5,800 lb oops
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by alpo718, Dec 19, 2016.
  1. alpo718
    alpo718 Light Load Member
    54
    43
    Apr 20, 2015
    Well finally had to do the offload of shame. Had a trailer with a broken digital scale, and an air pressure guage that read whatever it wanted whenever it wanted. Add the fact that I'm in a loaner truck while mine is in for service, and that kinda made for a difficult load. Nonetheless, I loaded it like a spring ride, run the back til she plugs, and load the front with the front loaded to 32,500 and weigh. Tractor scale was waaaay off. I scaled at 85,800. Blew off the extra and am legal now. Just venting, really, but from more experienced bulk guys, is there anything I really could have done to prevent this or was up for a fight from the get go?
  3. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    Only time I have ever loaded where I had to figure out each trailer, I always got my empty weight and split the difference. Most places I loaded on a scale under a silo or conveyor. More then once the plant guys have overloaded me. Usually only around 2k though. Blow off for about 5 or so minutes, hit the road. Just sucks when there is a line of 10+ trucks and they have to shut down a scale to let you do it.
    alpo718 Thanks this.
  4. alpo718
    54
    43
    Apr 20, 2015
    Yeah this place you vac it on, and drive a mile down the road to an outside scale. I've never understood the mentally of a place that only loads bulk pneumatics, but doesn't provide a scale. SMH
  5. WiggleWagon
    232
    312
    Aug 17, 2016
    That makes it a pain. I've never done the vacuum stuff. I worked for a place where they did it with train cars, I never did one of those runs though.
  6. alpo718
    54
    43
    Apr 20, 2015
    Most of what i load is out of a rail car. Not too bad. I'd rather top load though. Or better yet go where u pull under their hopper and they load it. Especially nice if you are on a scale!
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Ive done that before transloading flour from a rail car. No trailer gauges so just use the tractor gauge and a hammer on the side of the trailer. This one particular load was in a trailer that loads all in the front because of the way the axles are under it. Got up to about 70 pounds on my suspension gauge and about 1/2 up the rear slope of the rear hopper from the sound of my hammer. Went and weighed and I was at almost 110,000 gross when I was shooting for 102,000. Loaded right about 72,000 pounds but my order called for 64,000. So back into the rail car it went. Lol
  8. wis bang
    wis bang Road Train Member
    3,363
    3,949
    Jan 12, 2011
    Levittown, PA
    This was always a problem, our loader used to look at the amount loaded in the railcar and determine how much each load HAD to weigh. He had an oversize blower and knew the right spot to throw a rock at to see if it was enough...he vacuumed 4 - 6 loads a day every day. I always knew when I overloaded, the road out of the yard wasn't paved and Matlack's R models had Armstrong steering so you knew at the first turn in the gravel that you had too much.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,132
    Mar 5, 2016
    White County, Arkansas
    I got tired of the Redfield people loading me to 110K in flyash. Dragged it back to west little rock to spend over a hour blowing it. So I started blowing down to 80K legal inside Redfield and my bosses said is there suddenly a problem? Why are we wasting 20 minutes blowing off? Without realizing a 80K tanker will blow off to his silo in 45 minutes rather than a hour and change. Duh.
    In my early bulk days we loaded directly on the scale. 80K DING! Snap the bolts and take off. (Actually 77,400 for a mack and 40 foot tanker, but no one enforced that in my time...) My molded stack of cement logs show about 350K pounds delivered daily 5 days a week for months. Millions of pounds easy. Most of which went into the cement divider in the middle of I-270. and at the Pentagon SIlos in Arlington.
    bottomdumpin and alpo718 Thank this.
  10. alpo718
    54
    43
    Apr 20, 2015
    Well got a trailer with everything working today, recalibrated the tractor scales, we shall see if this puppy reads weight correctly now.
