53" trailer... A very simple and dumb question...
Discussion in 'Questions From New Drivers' started by defencerulez, Apr 12, 2011.
  1. defencerulez
    defencerulez Light Load Member
    129
    14
    Oct 28, 2010
    In between the LAKES!
    I just realize that today is the first time that I've taken a 53" trailer out on the road... I've been working for half a year already, day in and day out I go with 28" trailers, double or even a triple... But I've NEVER taken a 53" trailer out on the road... Even when I got my license, I did the test with a 45" trailer...
    Question is, how do I do a right turn properly? Is that any tricks? Nobody ever taught me that, my trainer put all his time to train me all the tricks on the double 28. I've made a few turns with it today, it's always too wide, probably because I was being caution... But that raise a problem, what if I don't have that extra space, how much space do I need to make that turn? Or, how much space is required as a minimum?
    All I know is I can make a tight right turn with 28", I just need 1 lane, 45" trailer is 1.5 lanes, 53" is 2 lanes? Can I do it with less?
    I have no problem backing it, played with it quite a bit in the company yard...
    I just have never driven it out on the road and don't wanna side swipe anything... Well, I should say I've done it today, but it was all in industrial areas, main road and highways so I had so much space to manuver...
  3. bigjoel
    bigjoel Road Train Member
    1,573
    1,835
    Jan 20, 2011
    Houston, Tx
    If possible, slide your tandems up as far as you can, especially running empty.
    That will shorten the turns some. Swing it wide.
  4. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    The too wide turns won't get you in trouble.....
    Watch your mirrors and be ready to stop if the trailer jumps the curb.
  5. defencerulez
    129
    14
    Oct 28, 2010
    Yea, I know wide turns won't get me in trouble that's why I have been doing wide turns with it yesterday.
    However, I am interested in the minimum space I need to make the turn, and any tricks while I am making the turn. Because knowing it means I won't kill myself with an IMPOSSIBLE TURN!
  6. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    Too wide will get you in a ton of trouble !!!!!
  7. paulll
    paulll Bobtail Member
    27
    Apr 11, 2011
    quebec
    keep in mind the trailer axles follow the tractor about 1 lane in on a turn,ck the mirrors,never panic,or be hesitant about stopping,it happens,watch for other vehicles
  8. txladycando
    txladycando Bobtail Member
    18
    9
    Dec 7, 2010
    dallas, tx
    If you do slide your tandems up, watch out when backing or making really sharp turns, the back end of the trailer could hit something if you don't have much room.
  9. cruisecontrol
    cruisecontrol Medium Load Member
    340
    115
    Apr 13, 2010
    Rockingham, NC
    once the trailer tires reach the edge of the curb, crank it..lol you may need two lanes or maybe even more...ever try to turn on a street that was at a 45 degree angle? or tighter?
  10. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Swing too wide and watch the fool four wheeler try to turn inside of you. Dont swing wide enough and take out the light pole on the corner. Every turn will be different so you just need to get used to your turning radius. Lots of people have different techniques for their turns. Myself, I would rather do a button hook using the second and third lane over than have to make someone back up but it all just depends on the situation.
  11. Allow Me.
    10,685
    12,258
    May 28, 2009
    Rancho Mirage, Ca.
    It really depends on lane width and how many lanes there are. A 4 lane intersection with no "buffer area" is different than a 4 lane intersection with a 3' buffer,(like a bike lane). If there is a parking lane then 2 additional lanes (in the same direction) both from the street you are turning from and the street you are turning onto, you can turn from the slow lane into the fast lane with no problem. But be cautious of fire hydrants, telephone poles and pedestrians.
