5ek check valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bovinemoovers, Aug 27, 2014.
  1. Bovinemoovers
    Bovinemoovers Bobtail Member
    26
    Oct 30, 2012
    I've heard to run a check valve out of a 1mm or a 7cz in my 5ek to hold more pressure. Is anybody doing this and what were the results?
    William
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    you can but I would also bypass the return line that runs through the ecm if you already haven't and up date with the newer style transfer pump.
  4. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
    buddy of mine did this he instead of bypassing the ecm he run the return fuel though it works for him
  5. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    yeah you don't have to, but it eliminates a couple of 90 deg fittings when it is bypassed causing a little less restriction.
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Why would you run the hot return fuel thru your ECM. The ECM has fuel running thru it to cool it.
    Bypassing it all together is even more stupid.
    Dont you think the cat enginers designed it that way for a reason. Just sayin. Geez.
  7. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    not talking about running hot fuel through. im talking about bypassing the return fuel line that runs through the ecm and routing it direct to the fuel valve base.do it all the time never burnt an ecm up without it. it doesn't make much of a difference on the cooling of it and you get rid of a few 90 deg angle fittings.
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    This guy is talking about running the hot return fuel thru the ECM.
    I can't see that being good for cooling.
    But hey. Just don't run any fuel thru it. Don't need it any how , right. :biggrin_25513:
  9. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
    the fuel is not much hotter that at the end of the day ether way it runs its just carring the heat from the ecm my buddys truck has been like this for couple years no problems A
  10. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    that's how they are setup from factory. the return fuel (IS) ran through the ecm on a 5ek. bypassing the ecm and routing the line straight to the valve control body eliminates running it through the ecm. or better yet install the newer style filter base from a 6nz or newer and eliminate the extra valve base and all those extra fittings that restrict fuel flow.
  11. Cat sdp
    Cat sdp . .
    20,861
    72,070
    Apr 8, 2012
    Orion's Belt
    They do things for a lot of reasons..... Performance and our satisfaction aren't always at the top of their list......
    superhauler Thanks this.
