5th wheel junk?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ErieMcDreary, Oct 25, 2019.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    Holland FW35Z800XL00, non slider, 540,000 miles, gas tanker, Volvo truck.
    I was feeling some movement between truck and trailer, especially taking off and stopping, showed it to mechanic who said "some movement in jaws, but also bushings.
    I tightened the nut 1/2 turn which helped a lot, but as I was looking over the bushing area to see how to change them, I noticed the inner holes where the pivot pins go through the ears on the 5th wheel, (not the bushing) is wallowed out so there is about 1/4" between the pins and hole edges on one side, the other side is egg shaped. I haven't pulled the pins and since the pin head covers the hole on the outside, I don't know if those are the same. I assume that's where most of the movement is now coming from. The bushings are actually rubber, so even with new bushings I think I would still get movement.
    I may be able to get pics this weekend.
    Is there a fix, recall, or is it just worn out?
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    just get a new fifth wheel and be done with it
    BoxCarKidd Thanks this.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Are yoou talking about the bushings where the fifth wheel is mounted to the stands, if so just change them.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,436
    6,472
    Aug 26, 2014
    Tanks are hard on 5th wheels. I often rebuild them but not if the if it has other problems.
    So go with truckdriver31! I thank Jost makes a plate that will go on those Holland mounts also. You might check and compare prices. Not recommending anything. Hollands have a long track record and it is good.
    Goodysnap and spsauerland Thank this.
  6. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
  7. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Well that pic didn't work.
    New Jost plus upgraded bushings for $825
    truckdriver31 Thanks this.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I would adjust that Jost everytime you change your oil with a tank. I find them to be inferior to a Holland. Rebuild our Holland's, but we have no-tilt tops for frameless.
    Oxbow, BoxCarKidd and truckdriver31 Thank this.
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    order monday am
  10. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    [​IMG][​IMG][​IMG][​IMG]
    There I got it to work. It almost looks like the pins are worn a bit, but I don't think it's as bad as I first thought. Anyone know what the spec is for too much wear?
    The Jost has a 5 year warranty, and the bushings a 3 year warranty.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    man i would use a crow bar on the outside under the pin. push down and up. check the play. if it has play. replace bushing and pin. if fifth is old with lots of miles. just go new
