Hi,
I'm relatively new to pulling vans although I have a lot of flatbed experience. I'm trying to get best MPG and reduce my gap between truck and trailer. The problem is, under real heavy loads, sliding the 5th all the way forward puts over 12k on my steers. The simple solution is slide the 5th back to put the weight on the drives, but that would make a larger gap and thus worse mpg. Sliding the tandems mostly takes weight off the drives. So, I know dot doesn't care about being a little over on your steers, but how bad is it for the truck? Assuming I inflate the tires to handle it, will it damage the suspension and axle to drive 500 pounds over on the steers? On yesterdays run my MPG seemed to be about .5 mpg higher then normal with the trailer tucked in right behind the truck and she seemed to handle real nice with the extra steer weight. I certainly don't want to trade damage to the truck for a little mpg though.
I drive a 06 Freghtliner Columbia with a detroit. The obvious solution is buy longer rear fairings, but until then, is it bad for the truck to run a little over on steers?
5th Wheel location
Discussion in 'Questions From New Drivers' started by Richter, Dec 15, 2013.
Page 1 of 4
I refuse to run over 12,000 on steers. I'm OK with 11.6k-11.9k as a matter of fact, empty or loaded (T700 for example) but these roads and bridge approaches are too bad in areas to be riding around with 13k on the steers. I also suspect that steer tire wear will accelerate in proportion to typical steer tire weight. You have to be sure if you suck it up too far that your mud flap hangers don't get tore up turning over other-then-flat roads on the landing gear structure.
But I say this as a company driver who doesn't fret too much over a little MPG loss and who works for a company who doesn't buy into this whole "green, low carbon emission" crap. Sensible driver, sensible speed, sensible tractor aerodynamics, if that doesn't get you into an MPG you can make money with, you need to find another business to run.Skydivedavec Thanks this. -
I don't think that sliding the 5th wheel forward 3-4" alone will increase MPG's .5, there must have been some other variables too. But to answer your question, I don't think an extra 500 lbs. won't hurt the suspension/tires, assuming they are all in good shape and have been PROPERLY maintained. Newer trucks are coming from the factory with 13,500 lb. rated axles for this very reason. Make sure your steer tires are rated for 6750 lbs. You must also remember if you get the right cop you will get a ticket no matter what you do.
Richter and Skydivedavec Thank this. -
I see some reefers where the unit is not more then about 18 inches from the back of the cab. I don't know if they are doing this to help MPG or they are doing this in a feeble attempt to "scale their load" but we store our load locks on the back of the cab and I appreciate a little room to access these without dealing with a trailer where deck plate access should be.
Richter Thanks this. -
That 500 lbs over on the steers should only amount to about 4" on the fifth wheel slider. As bubbanbrenda said, that is the typical distance between being at 12k versus 12.5k
So what I'm/we're trying to say is I doubt that 4" change in gap (talking only 500 lbs over) is even worth it, as far as "aerodynamically" gained mileage compared to all the negatives it brings from being "slightly" illegal on the steers, DOT bear with a case of the crabs, being number 1.Skydivedavec Thanks this. -
Richter, Skydivedavec and Lux Prometheus Thank this.
Agreed but we've seen plenty of posts from new drivers (and there are plenty of them today) who are screwing around with their 5th wheel position in an attempt to lighten their drives instead of adding weight to the trailer thus removing from the drives. Don't give California any more ideas then they already have by advocating for a minimal BBC gap. It may save a bit of fuel, but I'm leaving mine where it's at and still exceeding the target. I do not want to truck in a world full of European style trucks, thank you.
Richter and Lux Prometheus Thank this.
Page 1 of 4
