5th wheel slide
Discussion in 'Questions From New Drivers' started by BigMuthaTrucka, Oct 21, 2013.
  1. BigMuthaTrucka
    BigMuthaTrucka Light Load Member
    166
    76
    Mar 28, 2012
    West Valley City, Utah
    When I'm trying to slide my 5th wheel into another hole, do you lower your landing gear?
  3. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Yes otherwise it won't slide.
    DoneYourWay Thanks this.
  4. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    It helps if you are loaded and want to slide your 5th wheel to drop the landing gear. It takes some of the load off the 5th wheel. It helps to put some kind of lube on the sliding surface also. I use motor oil. Grease builds up gathers dirt and crap and seems to get everywhere you do not want it. Penetrating oil will work too. It does not hurt to spray the dogs that hold the 5th wheel in place on the track. If the dogs do not jump out when you flip the switch in the cab, set trailer brakes, release the tractor brakes and gently rock the truck. If they still do not release smack them with a hammer. If that does not work there is a good chance the cylinder that releases the dogs is shot, then you have to replace the cylinder.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,829
    Sep 10, 2010
    Flint, MI
    Also, once the landing gear is lowered dump the air bags if you have the option. I'll make the 5th wheel slide even easer as it will still be locked to the kingpin but will not ne holding any of the trailer weight.
    - Steven
    DoneYourWay and Grumppy Thank this.
  6. okiedokie
    okiedokie Road Train Member
    12,785
    97,269
    Jun 13, 2011
    PNWET
    Or your mty and it doesn't matter.:biggrin_25522:
  7. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    But it's not going to slide at all irregardless, if the latch pins don't retract when you "unlock" the 5th wheel. Make a visual inspection and insure they all 4 look like that have retracted. Like the trailer, sometimes you may have to buck and rock forwards and backwards until they all release. They stay stationary so long, the sometimes get really stuck especially on older trucks.
  8. koncrete cowboy
    koncrete cowboy Medium Load Member
    638
    331
    Jun 11, 2013
    Pennsylvania
    My stationary 5th wheel wont slide...any ideas?:biggrin_25520: lol
  9. The Admiral
    894
    561
    Jul 18, 2010
    Akron,Ohio
  10. HotH2o
    HotH2o Road Train Member
    4,098
    4,866
    Sep 23, 2012
    I use dish soap to slide my 5th wheel. Use it to slide tandems as well.
    okiedokie, The Admiral and DoneYourWay Thank this.
  11. HotH2o
    4,098
    4,866
    Sep 23, 2012
    Cutting torch??
    koncrete cowboy Thanks this.
