2017 Freightliner M2106 with 6.7 Cummins (Matco Tools truck) started running hot around 215 degrees going down the highway at 70mph. Water temp goes to normal as soon as truck starts idling. Outside air temp today was around 90.
Has Allison 2100 HS automatic transmission.
6.7 Cummins runs hot at highway speed and normal at idle
Discussion in 'Freightliner Forum' started by Larry-matcotools, May 28, 2019.
215 really isn't all that hot. What temperature was it running at before in similar weather conditions?
180-190. Just started creeping up this past week. Trying to be proactive instead of reactive in case there is s problem. I can’t sell tools if truck is in the shop.
How do the radiator/condensor/ charge air cooler look? No debris/dirt packed in the fins or between all the coolers? No folded over fins?
swaan Thanks this. -
All clear. Truck has 38k miles and 3800 hours on engine.
Agree^^^^^^
If it only does it on the hwy and not sitting still it's an air flow problem. Your cooling package (rad,condenser,charge air) is blocked or plugged up.
I'd take the front end apart and wash each core thoroughly. -
Are you sure? Some times the condenser sandwiched between the other cores can be plugged up and you cant see it unless you take it apart
Have you burped the cooling system? On a cool engine, open the radiator cap, start the truck, lightly squeeze or burp, the upper radiator hose while the engine is running, if the level drops add coolant until you top it off. Had a similar issue with my 6.7. This fixed it.
Rideandrepair Thanks this. -
It’s a long shot, have the cap pressure tested.. A bad cap causing low operating pressure, can cause it to run hot. Or so I’ve been told, on newer systems,
