6 axle with 60" spread on tractor
Discussion in 'Heavy Haul Trucking Forum' started by flat-step, Feb 2, 2018.
  1. flat-step
    flat-step Light Load Member
    96
    21
    May 11, 2011
    Hello all,
    Does anyone has a 60" spread in the drive axle of the tractor and 55" inch on the tridem of the trailer. Just wondering what's the max one can haul with that spread. I've hauled CAT 980's on a tridem RGN with the tractor drive axle spread at 55" and 55" on the trailer but it really makes the drive axle heavy. Was wondering if a use a tractor with 60" spread at the drive axle tandems what diff would it make on the weight.
    Thank you,
  3. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    Depends on the state.
    SAR and snowman_w900 Thank this.
  4. flat-step
    96
    21
    May 11, 2011
    Thanks for the quick response. I'm mainly concerned about IA,IL,IN,MI,MD,PA,NY. Thanks again it's people like yourself that makes this site a goldmine of good and credible info.
  5. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    Well I'm not sure where to start, I've read your question a couple times and I think one of us is confused. To my knowledge none of those states differentiate between a 60" spread and a smaller one, I could and may well be wrong. I run a 60" spread because it used to benefit us in ohio but not anymore. I used to haul 980's on a tandem tractor all the time, what is your weight on the drives with a 980 on?
    SAR, snowman_w900 and Oxbow Thank this.
  6. flat-step
    96
    21
    May 11, 2011
    Almost 36k on drives with a 244" wheelbase 379 and tridem 55" spread trailking. I'll have to dig out the scale tickets to get numbers. Thank you sir
  7. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    I'm still confused, you can easily permit more on the tractor.
  8. flat-step
    96
    21
    May 11, 2011
    what's the max you have permitted?
  9. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    Depends on the state. 50,000 in Ohio.
  10. flat-step
    96
    21
    May 11, 2011
    on the tandem? wow
  11. Oxbow
    Oxbow Road Train Member
    13,356
    138,336
    Nov 24, 2015
    55,000 in Wyoming.
    SAR, snowman_w900 and johndeere4020 Thank this.
