60 series detroit, ,,,,low oil pressure when engine at operating temp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brutus16097, Sep 20, 2013.
  1. wore out
    wore out Numbered Classic
    16,083
    194,803
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Pull the pan and pressurize the coolant system. That will tell you if it's water pump, air compressor, liner, or head gasket/head issues. You may have to roll the piston to the top if coolant is coming from a cylinder to determine if it's a liner or coming above it. I have seen several 12.7 compressors put water in the pan. Most times they put water in the tanks to
  3. Craig Ray
    Craig Ray Bobtail Member
    10,000 on inframe and oil pressure is 35to38 psi. Oil temp at 200 degrees. Am I harming engine? And what could be causing this?
  4. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    Did you replace the oil pressure regulator and the oil pressure relief valves. At time of in frame? Why the inframe, have you had a failure that left metal debris, oil pressure is oil pressure. With a fresh Inframe you should be north of 60 lbs. What model ddec 3 or 4?
  5. americanmadetrucker
    americanmadetrucker Logistical Engineer
    896
    3,279
    Jul 3, 2012
    Love my Detroits.
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    With 15w40, pressure on my 60 and normal operating was around 49-50 since day one. Been on a 10w30 for some time and pressure runs 46-48 at operating temp. Engine runs so much better as well, especially at start up.
  7. Cnotte
    Cnotte Bobtail Member
    I'm having the same problem after getting an end frame I don't know why the mechanic keeps telling me it's the EGR when I know the EGR has nothing to do with it I'm thinking maybe he did something wrong inside of the motor or down in the oil pan area
  8. tobie town trucker
    tobie town trucker Light Load Member
    105
    24
    Jan 12, 2011
