670 with d13 lost power and mpg after repairs
Discussion in 'Volvo Forum' started by Doug Ibrahim, May 17, 2023.
  1. Doug Ibrahim
    Doug Ibrahim Bobtail Member
    16
    Oct 28, 2015
    2016 volvo 670 with d13 engine with 700k miles. Went to the dealer after getting stuck in derate. They replaced the 7th injector, cleaned the dpf filter, cleaned the fuel system due to algae, and replaced the injectors. Truck runs but I've lost power and mpg. Before repairs I was getting 7.2 with 45k load. Now 6.0 is the best with a 36k load at 60mph. Any small hill immediately drags it down as if I'm pulling a full load up a steep upgrade. Any ideas would be helpful. Thanks
    Bean Jr. Thanks this.
  3. Socal Xpress
    1,854
    1,954
    Dec 6, 2014
    Los Angeles, Ca
    Take it back. Is it throwing any codes? Maybe the valve adjustment wasn't set right by the mechanic at the dealership.
  4. Doug Ibrahim
    16
    Oct 28, 2015
    After a week of running the check engine fault came on. I also believe the Def sensor is bad as it is always showing full so I have to fill it periodically to avoid any issues.
  • Draft saved Draft deleted
