6nz cat 175 thermostats
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigstank, Jun 10, 2013.
  1. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    Hey can someone give me the part # to put 175 thermostats in my 6nz. Not 180 or 190s but 175s. It can be done, I did it b4 but I forgot the cat part # for the 175s thanks...
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Not 100% on these numbers,so check on them, but i believe they are numbers your looking for??? :biggrin_25514:
    4W4011- 170F
    2485513- 180F
    2477133- 190F
    7W0371- 200F
  4. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    Why would you want a truck to run that cool?
  5. bigstank
    87
    19
    Mar 4, 2013
    missouri
    When u push a lot of hp... a cooler running engine is a better running engine, well at least my cat runs better cooler.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    you don't want it to run too cool. put a 180 and a 190 t-stat in, it works great! also if you have the $$$ install an a-cert high flow water pump. it will pull the hot water away from the liners faster. you will have to change the outer t-stat housing and the back plate on water pump for this to work. and maybe the oil cooler neck if you have clearance issues.
    bigstank Thanks this.
  7. bigstank
    87
    19
    Mar 4, 2013
    missouri
    What's the acert part # for the water pump
  8. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Have to agree. I got my first real start turning wrenches on demo derby cars so I got instilled in my young brain that heat's the enemy. Ran those cars with no thermostats just trying to keep it going till the final round. Now fast forward 8 years to my truck driving / owning / mechanic career and 'heat' isn't nessecarly the enemy but overheating is what you wanna get worried about. Driving older trucks with lower designed operating temps I got real concerned whenever I would drive my old man's new truck around all day at 180. But I finally had to figure that those engineers at CAT might just be smarter than me. Keep your cooling system in it's entirety up to snuff is the biggest deal, clean A/C radiator, charge air cooler, engine radiator, oil or trans coolers that may be mounted up front. Fan clutch, fan clutch air hoses and solenoids. Few months ago I lost my fan clutch pulling up a hell of a mountain loaded and got my truck up to 230 got me real concerned. After replacing solenoid, hose and clutch (we think it was a deteriorating air hose that took out the clutch) for about 3 days driving it I could swear my Pete sounded different, I was all worried thinkin I took out my head gasket or messed up a liner or something. Then a ol boy told me about the 'penny trick', which I wish I knew when I lost my clutch, and also I quote 'A Cat ain't runnin right unless it's runnin hot'. Amazing how advice from good ol boys who have been truckin forever can put your mind at ease.
    I can see your situation though, last summer we had to haul a backhoe up to the top of that same mountain pass by our house and got all sorts of warning lights on my dad's 07 (has a C-15 Acert MXS) and It would've been nice to be able to cool it down to 150-120 before starting the climb. Weren't even heavy as per over the road, but heavy for that pass it has a 60,000 weight limit and we were close to that if not a bit over. I'd try getting in touch with Mr. Haney. I know that dude makes bookoo power with Cat's and would sure know anything you'd need.
