6x4 -6x2 mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Oct 31, 2011.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    Hi my question is what is the diferent betwin 6x4 and 6x2 and is a diferent in mpg or is the same what is more economic
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    6x4 is a standard tandem drive
    6x2 is a tandem drive configuration but only one axle (usually the rear) drives> This configuration is more fuel efficient as you are only turning one set of crown and pinion gears.
  4. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    We are seeing almost a one mpg increase running the single rear axle trucks. Same load weight and terrain as our 6x4's 90% interstate, I doubt that you would see much differance with local or regional runs with a lot of stopping and starting. JMO
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    We've got one 6x2 and it absolutely kills tires. It was built to be light (which it is) but at the rate it kills tires I'm not sure any added fuel mileage would cover the tire loss. The only way it is worth it here is the added payload plus any fuel might cover the tire costs.
    It's a W900 daycab with a C12, dead axle and super singles. It pulls a grain hopper and does all short hauls. No matter how easy you let out on the clutch it will slip the drive tires in gravel. You can dump the air off the dead axle which is required when empty but doesn't help much loaded since it bottoms out the suspension so both axles still carry the weight.
    If you were OTR it MAY pan out, If you can benefit financially from the added load capacity also helps but if your paying someone to convert a truck hoping to pay for it with fuel savings it may take a long while.
