7 Axles with an 80,000lb Trailer?
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, Jan 30, 2018.
  1. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Hey all.
    I am currently running a 3 axle truck and a 2 axle RGN with a flip. I can haul up to about 65,000 lb payload and I weigh 42,000 lbs empty.
    I am considering purchasing a 4 axle truck to increase my capability, but I was thinking maybe the 80,000 lb trailer may limit my payload. Shouldn't the trailer limit exceed the axle limit? Would it make sense? Or, would the trailer have to be changed to maybe 110,000?
    Thanks in advance!
  3. johndeere4020
    8,522
    119,296
    Jan 1, 2010
    What's your swing clearance?
    SAR, snowman_w900 and cke Thank this.
  4. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Good question. I'll have to check and get back on that.
    That's king pin to the neck, right?
  5. johndeere4020
    8,522
    119,296
    Jan 1, 2010
    You don't know off the top of your head?
    SAR and snowman_w900 Thank this.
  6. johndeere4020
    8,522
    119,296
    Jan 1, 2010
    Yes
  7. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    It's 84". You thinking it's not enough for a 4 axle truck?
  8. johndeere4020
    8,522
    119,296
    Jan 1, 2010
    I'm tired and I have a splitting headache, short answer? No 84" is no where near enough, if your interested and can handle frank conversation I'll elaborate later.
  9. TripleSix
    134,899
    84 inches is 7 ft. The 2 drive axles and the lift axle are going to be 9 ft. And that’s just the tires, meaning, you need space for the bobtails frame/rgn ramps, headache rack...etc... to turn without binding up in the trailer.
    Forgot to mention, if you cant slide the fifth wheel forward enough to get weight on the steers with the lift axle down, you failed.
    stwik, Hegemeister, SAR and 2 others Thank this.
  10. johndeere4020
    8,522
    119,296
    Jan 1, 2010
    Did I fail?
    Oxbow, Hegemeister, SAR and 1 other person Thank this.
  11. Rontonio
    Rontonio Road Train Member
    6,574
    48,849
    Aug 9, 2009
    And all you then do is take weight off of the steer axle - nothing like having 9k on the steer
    stwik, Oxbow, Hegemeister and 4 others Thank this.
