Not sure where to ask this so since I'm still a new driver (1 year experience) I'll ask it here.
I just started with this small company and the load they sent me to pick up is 700 pounds over on the steers. After messing with it all last the and the shipper not actually moving anything in the trailer to help my company is telling me to take off with it. I'm 99% sure I'm going to get pulled into a scale even tho I'm only going 500 miles. Question is will DOT let me blame my company or does it still fall on my shoulders that it's not legal. And should I tell them I'm not going anywhere until it's fixed?
700lbs over, what should I do
Discussion in 'Questions From New Drivers' started by Greywalker, Jun 19, 2018.
Page 1 of 7
That’s a hard one: we have a 450 lb overage allowance due to our apu’s So; I would probably run with it since I’d burn off fuel along the way: figure fuel runs 7 pounds a gallon and how many miles do you get per gallon and how many miles away are you from the scale......
What is the weight of steer axle as well as both sets of tandems..
Kyle G., Broke Down 69 and SteveScott Thank this.
Slide your 5th wheel back one notch and go.
Slide your 5th wheel back one notch.
Oldironfan Thanks this. -
How much do your steers weigh? Technically, your legal steer axle weight will be the lesser of either your steer tire rating, or your steer axle rating. 12,500lbs on the steer is usually always safe, but legally it could be less depending on your specific truck specs.
Also keep in mind the fuel. How much do you have in the tanks? Diesel is approx. 7lbs a gallon I believe, and when it gets burned off most of the weight is taken off your steer axle.
So if you have a light steer axle (say 11,500) you could move 1,000 lbs from the drives to the steers by sliding the fifth wheel forward about 2 notches, towards the steers. Then if you are full on fuel you know some of that steer weight will drop when you start burning through your fuel.silverspur, Lepton1, x1Heavy and 1 other person Thank this. -
What does the steer actually weigh? Are you using 12k as the max weight? A single axle can be 20,000 lbs. should the axle and tires be rated for same.
KB3MMX, Lepton1, x1Heavy and 1 other person Thank this. -
Page 1 of 7
