72mph # Swift Will get you FIRED
Discussion in 'Report A BAD Trucking Company Here' started by Xsd, Nov 20, 2010.
  1. Xsd
    Xsd Bobtail Member
    26
    Richmond, VA
    72mph # Swift Will get you FIRED,
    They did to me without warning. Crazy right.
    My truck broke down and it would take weeks to fix it. So instead of finding me a new truck they just fired me to save them the work to find me a new truck. Only worked there for 1mo. (They said I over speed 3wks ago)
    All Well, After a 1 1/2 of trucking I had a smile:biggrin_25525: everytime I steped out of my truck # .25cpm a year ago to a Awful after taste:biggrin_25510:. and Im just only 23yr
  3. Eagle_Eye
    Eagle_Eye Medium Load Member
    389
    220
    Sep 26, 2010
    ClarksvilleTennesse
    Probally did you biggest favor they could look into newvie companies stay away from L/P deals
  4. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    Swift pays .25 per mile:biggrin_25524:
    People actually get behind the wheel?
    JimDriv3r Thanks this.
  5. DickJones
    DickJones Road Train Member
    1,287
    592
    Aug 16, 2010
    maybe it was cause you couldnt read numbers? After all, you use a "#" instead of the "at"...difference between using a 3 and a 2 with the 'shift' key. Kinda like using the clutch to shift, you probably can't to that right either.
    congrats...
    scottied67 Thanks this.
  6. Eagle_Eye
    389
    220
    Sep 26, 2010
    ClarksvilleTennesse
    Well, well, If going to criticize his typing, maybe you should learn to spell.
    Using T instead of D is like turning left, instead of right.
    red S-10, Pur48Ted, trukngrl and 14 others Thank this.
  7. DickJones
    1,287
    592
    Aug 16, 2010
    hahahahah.....and as bad as you call swift, and how bad everyone says swift must be.......you still got fired by swift......meaning, you wernt good enough for 'bad' swift. hahaahhahahahaha i'm dying over here......too funny !!!!!
    please tell me you made this up?
    DC CAB and scottied67 Thank this.
  8. Lilbit
    Lilbit Road Train Member
    16,583
    12,232
    Aug 4, 2008
    Let me check my logbook
    How the heck can you go 72 mph in a swift truck? Downhill with a tail wind? They are governed at about 63 mph.
  9. Xsd
    Xsd Bobtail Member
    26
    Richmond, VA
    No Werner when I first started
  10. mindcrime83
    mindcrime83 Bobtail Member
    29
    22
    Aug 31, 2010
    St. Louis, MO
    if you work for a company, and they give you certain rules to follow, and you break them, you are going to get fired. i'm not sure what you thought would happen here. all swift trucks are regulated at 63 (68 in the older ones). so if you were running one of their trucks at 72, you were clearly messing with something you shouldnt have been. if you were running your own truck, then you should not have taken a job with a company that required you to drive slower than you were willing to drive.
    all in all, sounds like YOU were the one that messed up, no matter which way you look at it.
    i am also confused by your post. first you state that you were driving 72 and they fired you. then you state that your truck was broken and they fired you for that. these two options are mutually exclusive. if you are looking for pity, you are going to have to clearly explain what happened and why they fired you. otherwise, we are all going to assume you drive as well as you explain yourself and assume it was your fault.
    DickJones Thanks this.
  11. AF461
    AF461 Medium Load Member
    380
    167
    Oct 7, 2010
    Dover, DE
    Now that's funny, I don't care who you are....:biggrin_2559::biggrin_2559::biggrin_2559:
