77' kw k100 adding power steering
Discussion in 'Trucks [ Eighteen Wheelers ]' started by flc120, Oct 27, 2015.
  1. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    Looking at purchasing a k100 i like the truck alot but it has no front bbrakes or power steering. How hard would it be to put it on truck? Im guessing i would need pump,new steering gear and lines with resivoir, besides this is this a costly conversion? And would i need a steering box off a cabover and not a conventional?
    Any help would be great
  3. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
    You failed with the Pete, so now you go to something that'll surely be work?
    1+1=6 now?
    drdesl and truckon Thank this.
  4. lots of character
    1,031
    1,814
    Aug 12, 2015
    My $20 would be, leave it arm strong and leave the brakes off.
    truckon Thanks this.
  5. AModelCat
    156,479
    I'm guessing power steering was an option back in '77 so it can probably be done. Might need to have some fab work done to mount all the components.
    drdesl Thanks this.
  6. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,430
    6,467
    Aug 26, 2014
    Hello again. The box does not care. I put Sheppard p/s from a c/o Freightliner on a 400 White. Also saw some one install a used box on a c/o Freightliner. The steering wheel and the ones on the ground turned in opposite directions, there are right and left hand threaded screws. Replaced air steering units with hydraulic p/s on conv. IHC's in 1986. Everything was new except factory reman boxes. Parts cost around $2200 per truck. If the truck did not come with front brakes they are not required by law but I am almost sure everything did by 74 or 75. The way you can find trucks look for a donor. If the box does not bolt up to the frame it can be a big hassel.
  8. AModelCat
    156,479
    My family must get the rare ones. My dad's old '78 W900, my '80 W900 and Uncle's old '84 W900 never had front brakes from factory.
    drdesl and lots of character Thank this.
  9. truckon
    truckon Swamp Thing
    4,775
    15,916
    Dec 16, 2011
    Like I'd tell you!
    Cant prime an engine but your going to add power steering? This should should be good.
    Adisiwaya, MJ1657, drdesl and 3 others Thank this.
  10. BoxCarKidd
    4,430
    6,467
    Aug 26, 2014
    Northern I just put that dating with the first trailers with anti-lock brakes. That was the 721 system which was discontinued because 7 too 1 they would fail. Ol Blue is a 71 with front brakes but it has an on off switch similar to a p/d switch it is labeled wet/dry. I am not sure what year they were mandatory but if the truck had them factory installed it was illegal to remove them. Some trucks, Macks, only had holes in the frame for air line bulkhead fittings if it came with front brakes. Smart Barney put them out of service for brakes out of specifications on two wheels.
    flc120 Thanks this.
  11. AModelCat
    156,479
    Gotcha.
    BoxCarKidd Thanks this.
