7FB JWAC to A2A
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Feb 8, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,416
    1,739
    Dec 4, 2019
    I’ve come across another A2A from a 4MG and I bought it but thought it may be of some significance on my 7FB. Is there any advantage? Does turbo stay the same or need to change?
  3. Oldman83
    Oldman83 Heavy Load Member
    860
    11,238
    Sep 5, 2024
    Marrowbone Ky
    Compressor outlet is different on a turbo for a JWAC versus an A2A setup, but you can pretty easily fab an adapter.
    mile marker 27 Thanks this.
  4. W923
    W923 Road Train Member
    1,420
    4,400
    Feb 28, 2022
    On an 855 Cummins it makes a huge difference in torque and egts
    I can’t imagine it would be different on a cat….they’re both similar engines.
    I’ve heard that a 400 jwac cat has the same fuel rate as a 425 a to a but never looked into it.
    As far parts it would probably be advantageous to use an air to air style intake manifold and obviously you would need the rest of the plumbing which would probably be reasonably easy to adapt from a similar truck. I don’t see why the turbo would need to be changed unless you can’t manage to connect it to the new system.
  5. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    I apologize but I failed to mention that I had an A2A intake manifold, from a core and planned to use it. I gotta get in the 7FB and do some work around nozzle jumper lines/fittings (I’m probably calling it wrong) and thought that’d be a good time to attempt this.
    W923, Oxbow and Oldman83 Thank this.
  6. W923
    1,420
    4,400
    Feb 28, 2022
    Those little turds can be quite frustrating. Seems like the stamped steel keeper often fails to properly hold the pass through piece
    Oxbow and mile marker 27 Thank this.
