8 axles... Seriously?!?!
Discussion in 'Ask An Owner Operator' started by tomkatrose, Aug 17, 2012.
  1. tomkatrose
    tomkatrose Light Load Member
    224
    161
    Oct 22, 2010
    Los Angeles, CA
    I haven't driven in WA or OR (but we've had a lot of our trucks running up here). So this past couple weeks, I've been back and forth to Seattle and Portland and noticed all the axles on the trucks and trailers. I can appreciate if there are some roads that require it for the weight and I see third axles a lot when I go to Toronto. Proportionately, there are more trucks with more than 5 axles than not. Today, I passed a Columbia pulling a 32' dry van today, the truck had 4 axles on the road and the trailer did too. It looked like a centipede.
    Can anyone give some insights as to why the trucks up here have so many axles? Makes me want to get out of trucking and into tire repair in the northwest.
  3. Frenzy
    Frenzy Medium Load Member
    331
    186
    Mar 24, 2008
    Seattle, WA
    Oregon has a vehicle mile tax that is based on the number of axles. The more axles you have the lower the tax is. So Oregon really rewards you for having a lot of rubber on the road. Also most of the PNW allows 105K lb combinations.
    SHC Thanks this.
  4. Crazy D
    Crazy D Medium Load Member
    493
    240
    Mar 18, 2011
    Homewood,IL
    Lol. Then you need to goto Michigan. Check those bad boys out. Something like 8 axles on the trailer alone.
    SHC, MNdriver and heyns57 Thank this.
  5. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    I'm one of those 8 axle drivers. 4 on truck, 4 on trailer. This allows us to run up to 105,500 lbs net. Good for steel, and paper rolls. But yeah, tire checks are a pain....:biggrin_25523:
  6. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Used to drive for this company out of Virginia
  7. tomkatrose
    224
    161
    Oct 22, 2010
    Los Angeles, CA
    So I would assume each additional tandem gives another 20K lbs if not spread and the single drop axle would give another 12.5K lbs but that doesn't add up to 105.5K lbs. What's each one worth?
    More importantly, are you getting paid by the gross so the extra weight is that much more money for the load?
  8. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    105,500 NET???
    Thats 150K gross. No way.
  9. Bikerboy
    Bikerboy Light Load Member
    299
    183
    Apr 1, 2008
    Canada
    Here in Ontario we can run up to 63 500 kg ( 140 000lbs), usually requires a 5 axle trailer and regular 3 axle tractor or sometimes 7 axle total is enough with a 20 k front axle on the truck
  10. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    If the front axle is rated for 16K, just a 4 axle truck is rated for 76k, and that's BEFORE you add the trailer. Add another 80k for the trailer with 4 axles.. yeah, that's well over the 105.5k
