8 days in 30 elogs
Discussion in 'Trucking Industry Regulations' started by Bdog, Mar 11, 2017.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    https://www.fmcsa.dot.gov/faq/what-exceptions-are-allowed-electronic-logging-device-rule
    There is an exemption for the elogs requirement if you do not have to log more than 8 days out of 30.
    I think I will meet this exemption as I mainly drive hauling our own equipment to jobsites and then I work there for a week or two and haul it back home.
    My questions are this seems a little vague. If I go over 8 days do I just blow my exemption for that 30 day period or is it forever?
    Looking back I think I have logged over 8 days in a 30 day period maybe three times in the last five years.
    Dave_in_AZ and Oxbow Thank this.
  3. brian991219
    brian991219 Road Train Member
    2,927
    5,828
    Aug 10, 2013
    Lords Valley, PA
    My take on it is if you go over 8 in any 30 you only need elog for that month. As you describe your operation you have to log the trip from your base to the job site then you can go 100 mile rule for each day you leave from and return to the job site in 12 or less hours (assuming you stay within 100 air mile radius). Then you would log the trip back home. These two trips have to be logged because you left from and returned to a different place on that particular tour of duty, even if the job was within the local radius.
    Now, depending on what your industry is and if you cross state lines or not you may have more permissive intrastate hours of service rules and may not have to comply with the Federal rules. The elog rule only applies to interstate motor carriers (private and for-hire property or passenger) unless your state is one that adopts the Federal rules by reference, then your intrastate rules are the same.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    8 days out of 30... next 30 you start fresh again
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    It's a rolling 30 days. Just like your 70 in 8.
  6. firecatf7333
    firecatf7333 Light Load Member
    175
    59
    Oct 28, 2012
    If I worked 2 days per week OTR...then worked the rest of the week 100 mile radius( no log book needed) and amounted to 8 days needing to log per month..would that mean I wouldn't need ELog?
  7. brian991219
    2,927
    5,828
    Aug 10, 2013
    Lords Valley, PA
    Correct, just watch how the calendar falls because it is a rotating 8 in any 30 day period. You could exceed that limit if you are not careful.
