82 peterbilt 359. Air buzzer problems need wiring schematic if possible
Discussion in 'Peterbilt Forum' started by Bryson13, Jul 31, 2014.
  1. Bryson13
    Bryson13 Bobtail Member
    18
    Oklahoma
    Iv got an 82 peterbilt 359 with 3406b cat in I'm having problems with low air buzzer and the low air switch. The low air switch is brand new and so is the buzzer. Both the wires coming off of the low air switch are hot and doesn't change when the air pressure is up or down. I can unplug one wire coming off the low air switch and apply ground to the other side of the buzzer and the buzzer works but doesn't shut off. Does anyone know where i could possible get a wiring diagram??? Iv looked on Google and can't find one or can someone tell me where might be the other low air switch would be considering that it's a split system. Thanks.
  3. wore out
    wore out Numbered Classic
    15,988
    193,559
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You are right ground one side of the buzzer. you should have power to one side of the low air switch only, when the pressure drops to 60 the switch makes contact inside and sends power to the buzzer. Pressure raises and switch becomes open again breaking the circuit. sounds to me they gave you the wrong switch.
    Bryson13 Thanks this.
  4. Bryson13
    18
    Oklahoma
    Could it be possible another switch on the air block since it's a split system?? The wires that iv got and the ones I think that are right are red with a yellow tracer and green with light green tracer the red being the ign-voltage. Would them be the right wires??
  5. wore out
    15,988
    193,559
    Jun 5, 2013
    My 85 and 86 only have one. There are so many extra wire in the dash it could be that they have two seperate power circuits run to it. Color isn't as important as wire number. Just trace the power in you should only have one power in
  6. Bryson13
    18
    Oklahoma
    Right. I don't really know which number they are iv been looking for diagrams I can't find any at all. They darn sure don't let that crap out that's for sure. So that red and yellow wire and the green and light green both go to that low air switch?? I don't know much bout trucks at all I'm just kinda learning on my own as I go.
  7. Bryson13
    18
    Oklahoma
    Are the wires coming from the low air switch the same ones that go to the low air buzzer?
  8. wore out
    15,988
    193,559
    Jun 5, 2013
    yes the light and buzzer come on together. So they share a circuit
  9. Bryson13
    18
    Oklahoma
    Is there supposed to be voltage on one side of the low air switch and nothing on the other side of the switch?? If so I think I may have a faulty switch cause iv got voltage on both sides of the switch and it doesn't change when it builds air above 60psi.
  10. rank
    rank Road Train Member
    9,918
    113,504
    Feb 11, 2010
  11. Bryson13
    18
    Oklahoma
    Thank you very much. On that diagram page one it's showing 2 low air pressure switches.???
