Just put a PTO and wet system on my truck which fluid should I refill the trans with? manal says "heavy duty motor oil" so should I just fill it with rottella and call it good?
8spd road ranger, which fluid?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BryRylanKW, Aug 20, 2011.
I believe I use regular 50 weight oil in trucks with 8LL's and mobil synthetic 50 weight in the ones with 18 speeds. I would have to double check to be sure, but I know on the side of the bucket it says they are intended for use in heavy truck transmissions.
Maybe try to find a copy of the 8 spd roadrangers owners manual on line just to be sure. -
Floyd is correct.
SAE 50 transmission fluid is what the Eaton website says.
1" of housing = about 1 gallon. Make sure it comes out the hole and not a little shy. -
So a 5 gallon of SAE 50 should do it?
Yes, a 5 gallon bucket will do it.
Napa cant get it so I need to find someone around here that has it
