9 - 10 mpg
Discussion in 'Ask An Owner Operator' started by TheEnglishMan, Apr 26, 2013.
  1. TheEnglishMan
    TheEnglishMan Light Load Member
    231
    60
    Oct 3, 2012
    So I was chatting with a driver from Messilla Valley Transport and he was saying they regularly get 9 - 10 mpg. Trucks & trailers are setup as follows:
    Prostar with Maxforce engine governed at 65 mph = 1500 rpm
    Single drive axle with tag axle - did not know this about their trucks
    super singles alround
    wheel covers on the tractor
    tractor trailer gap closed up as much as possible
    boat tail and side skirts on the trailer
    idle kept to the absolute minimum
    So basically it's all aerodynamics and rolling resistance, with no mention of keeping it under 60 mph or lugging the rpm down.
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    They also try to haul as light as possible. Not to hard as they haul for some of the same clients out of El Paso that we do. A lot of El Paso outbound freight is under 35k
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    My guess is that the single drive axle is the biggest contributor to their increased MPG. Between that and the 65mph limit, I'd say that accounts for the bulk of their fuel savings.
    KANSAS TRANSIT Thanks this.
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I would agree on the single drive axle. It saves somewhere in the area of 400-500 lb of weight compared to dual drives. And closing up the gap between tractor and trailer is a real plus also. They got a lot of our tax money as incentives to get a lot of this stuff. But I have to admit, they figured out and proved a lot of things that make sense.
    Scania man Thanks this.
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Prime is getting similar fuel mileage, but they haul heavy most of the time at 55-60 mph. Prime doesn't get any where near the fuel discounts that I receive.
    It's not just all the goofy looking aero gimmicks, it's also the gears in the boxes while operating at peak engine torque.
  7. snowwy
    snowwy Road Train Member
    20,564
    13,287
    Jul 6, 2009
    if i bobtail i can get 9.5.
    so i'm not seeing 8 - 9 happening with a loaded trailer.
    Raiderfanatic Thanks this.
  8. Crazy D
    Crazy D Medium Load Member
    493
    240
    Mar 18, 2011
    Homewood,IL
    get more MPG to haul cheap frreight. Yep that makes sense.
  9. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Yup that's how it's done in Europe, 1 drive axle ( 1mpg saving on average ) super singles everywhere except on drive axle, deep pin trailers to get it as close to the cab as possible, engines cruise at 1000-1200rpms so nowdays a 700hp+ semi will do 11mpgs @ 97,000lbs, a lightly loaded truck will get 12 mpgs, the cab-over design has a distinct aerodynamic advantage but yeah these little things make a huge difference
  10. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    Yep a point so many people miss running in you engines power range. I have a 1996 classic XL that's like throwing a brick at a hurracaine and I still get 6.5 to 7 I meet a guy in iowa that also has an older classic whos ecm report shoes 9 with and avg speed of 61. he said the biggest diffence makers was regearing and getting more power to the top gears and alittle less speed beefing up the motor and he said the quickest was cleaning out his fuel tanks.....
  11. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    Just curious how you get better discounts than Prime does.
