90 Degree and Offset Backing
Discussion in 'Questions From New Drivers' started by prosidius, Dec 7, 2016.
  1. prosidius
    prosidius Light Load Member
    252
    239
    Jul 15, 2016
    Wisconsin
    I have the CDL exam in 2 weeks and I want to nail down my achilles heal, backing.
    My offset backing (starting in the right/left lane, pull up to a cone and back into the lane/dock on your left/right) is ok. I can sometimes get it without tapping a cone. I find my problem doing offset right is getting too close to the left edge in the lane I'm backing into. Offset left I have the exact opposite problem, I'm not to the right enough to the point that I can't see the middle cones in my mirrors.
    90 degree backing I'm still mostly terrible at. For whatever reason my first attempt of the day at it is usually my best. My first attempt at it today I got the thing in there without a pull up but my second, third attempts I came nowhere close to getting it in and was constantly starting the maneuver over.
    Is there some secret to backing I'm missing? I got the inspection part of the test down and I'm confident I can pass the road test, but the backing test feels like it's going to be this brick wall.
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Even the old hands have days they couldn't hit a hole if it hair on it. Your driving the trailer, not backing a tractor. Test 90's are the easiest, other than ripping off a air line from jack knifing to tight.. you dont have to worry about anything other than where your going... take your time, see it in your head, kinda like riding a bike, where you look is where you go...
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Wind the steering wheel to start the trailer moving around to where you want it, unwind the wheel enough to follow the trailer. There is a possibility she will pop right into the hole and really unwind it to straighten up.
    Think about your trailer like a car with a really big front end (Your tractor) and watch your angle over the drives below the front plate of the trailer.
    You will find real world backing to be much more "Pre-cise" than your test cones will be. If your trailer has moved too far to the left side a pull up will fix that as long you have room in front of your tractor.
    In my day we used to have one move competitions at school. When everyone could do it it became a timed stopwatch race. Shortest time in wins. Hang in there.
    Remember in the real world your backing will be steady and slow with constant checks that include getting out of the cab and walking back there to check.
    There have been times Ive been told to pick a dock in a place with 30 docks open, a empty lot in front of all of them and due to fatique could not hit a one. Had to have one of the workers put it in for me. Just a little tidbit. Don't be over tired. It's worst than being drunk.
    street beater Thanks this.
  5. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    If you stay with trucking,eventually it (backing becomes second nature).After a long while...you pretty much know exactly how big your rig is and how much room you need and the angles etc.When I first started started sure,I was frustrated(getting the fish eye from dinosaurs that had been driving for 35 years).Sweat palming the wheel,sweaty head and all.Now its second nature.Your initial setup is what makes or breaks you.Try to keep as much of your trailer in view as you can and use your trailer tires as a pivot point guide.Im not above sticking my head out the window to see either.JMO
  6. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    Dunno if you started on a manual, Bumba... but I fondly recall bunny-hopping the truck into my first few doors. Getting the clutch to the point where it would catch and release the gear... Funny as hell now; embarrassing as the same then.
  7. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Kinda like the first time you forget to drop into low range at the light....
    KillingTime Thanks this.
  8. KillingTime
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    First time you didn't drop low for reverse..... Unexpectedly the thing takes off like #### thru a goose.
    joesmoothdog and street beater Thank this.
  9. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Hey mom! Lookie here! I can 25 in reverse!
    Oh ####! Im doing 25 in reverse!
    91B20H8 and KillingTime Thank this.
  10. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    I have been driving 9 years now and still have issues because I am never in the same truck two days in a row. I may go from one truck that has a very good turning radius to one that takes more than one would think to turn around. Last 90 degree back I did I got out and looked around 10 times. I didn't want to hit either trailer back there.
  11. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    1: when backing, you're driving the tandems, not the end of the trailer. Other than watching (get out and look) your right side to make sure your trailer doesnt overshoot, it's all about your tandems.
    2: lots of very good drivers have a hard time acquiring the skill of backing. Just keep at it and when you screw up, analyze what you did wrong.
    3: a toy semi and trailer can be very helpful in demonstrating how backing a trailer works. Well worth the money.
    x1Heavy and ASmallFleetDriver Thank this.
