90 degree backing question
Discussion in 'Questions From New Drivers' started by zoekatya, Jun 28, 2015.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    I'm always scared I'm going to hit the truck on my right side so I get out and look. Do I need to be worried about this if I'm close enough to the truck on the left? Also when do YOU start turning it in, when the tires on you left trailer are between the guys bumper on your left, I'm the middle?
  3. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    Getting out and looking, or GOAL is a very good thing to do, to ensure you WON''T HIT anything.
    For me to tell YOU when to start turning the wheel, is next to impossible. I know MY timing, and my truck and trailer reaction time.
    This is something you just have to practice, practice, practice.
    Big Don Thanks this.
  4. EndHatred
    EndHatred Medium Load Member
    513
    380
    Jun 9, 2015
    If the spot you're backing into is tight ALWAYS GET OUT AND CHECK until you have lots of experience. I can't advise you basically because it also has to do with the turning radius of your truck. Petes & KW's & any long nose truck with a longer turning radius are different to where they will push your trailer versus a short nose truck such as Frtlnr or Volvo. Even after driving for years if the space was tight I would "GOAL"/get out and look. Occasionally I'ld have to get out multiple times. Don't be shy about it, better to get out & check than to hit someone.
    zoekatya and Big Don Thank this.
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    What the above posters have said! If you don't make a habit of GOAL, then you will eventually hit something.
    Lepton1, brian991219 and zoekatya Thank this.
  6. 77smartin
    77smartin Road Train Member
    2,183
    3,023
    Apr 3, 2011
    I dunno.
    GOAL...the situation is never the same.
    brian991219 Thanks this.
  7. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    No need to be worried. Just back her on up. The truck will stop when you hit something....either the dock bumpers or the truck on either side of you. No need to get out and look.
    ajohnson and 2duisperyear Thank this.
  8. lfod14
    lfod14 Road Train Member
    1,178
    689
    Jan 9, 2014
    Honestly I don't have to do a lot of 90's but when I do If I feel iffy about it I GOAL. I used to deliver beer and now I'm doing P&D and have a LOT of really screwy places to stick my trailer, I should realistically be pulling a pup, but most of the time have a 53 in places where it has no place being at all. I'd rather GOAL 50 times and look like an incompetent moron, than be the guy that smashes my trailer into something.
    As far as judging the right by what you see on the left, that can be hairy. You CAN do that if your always in the same truck/trailer length and setup and know the place your backing into, but what if your judging the right by the left, but because of your space a couple stops ago you slid your tandems up and left them there (I do that all the time being in the city), now there's a lot more trailer behind the wheels, if your using them to judge the blind side, that can turn out bad. Something to keep in mind.
    texasbbqbest Thanks this.
  9. walstib
    walstib Darkstar
    You should always be concerned about it, but not scared...
    And never THINK you can make when KNOWING is only a 53' walk away!...
    Once I KNEW the space was big enough, I would focus on just being as close as possible to the left side knowing that would work...If it's very tight(rare) GOAL, your pride should never be hurt getting out to look! But hit something one day when looking would have prevented it, not the same! ;-)
    zoekatya Thanks this.
  10. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    I second this motion.
    Just toot your horn several times to let everyone know that you're in backing procedure and if you hit anybidy then you can blame it on them.
    HotH2o Thanks this.
  11. TheDudeAbides
    TheDudeAbides Medium Load Member
    374
    455
    Dec 5, 2014
    San Antonio, TX
    My trainer always told me to watch the trailer tandems. And get out and see how much space you have on both sides
