(9200I) Convert 10 speed to 15 on the hi side?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sodbuster59, Mar 1, 2022.
  1. sodbuster59
    sodbuster59 Bobtail Member
    12
    4
    Oct 10, 2021
    Can a splitter be added on the high side so as to convert Meritor 10 speed to a 15 speed? I’ve been told definitely yes AND definitely NO and am buffaloed.
    We have two internationals which are set up pretty similarly except in regards to final gear ratio. One is running 3.58 rears and the other 2.64’s so one is great for getting out of the field, but really revved out at 60 mph and the other other is 180 degrees versa vice.
    the other thing I thought of was swapping the 3.58 gears for 2.64’s on the one and converting them both to a low gear reduction 15
    thoughts?
    jamespmack Thanks this.
  3. wore out
    wore out Numbered Classic
    15,952
    193,018
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    There is no such creature as a 15 that splits the high side gears. All 15 are deep reduction on the low side. Also the 10 speed ratios are not spaced correctly to be split on the high side they are not even. A 15 speed has a different gear spread from a 10 so if you put a deep box on a 10 it won’t flow the same way through the gears.
    The 10 speed case and the 9/13/18 case is made completely different on the back so there isn’t a way to bolt the back box up. You also have to change the gear on the back of top shaft to put a 13/18 box on a 9 speed. Again this gear is different completely from what a 10 speed will use.
    Oxbow, beastr123, kemosabi49 and 5 others Thank this.
  4. jamespmack
    215,674
    Rockwell to my knowledge never built a 15 speed. Plus a 15 splits on the bottom, really won't change top end much. Rockwell meritor did have a 13 speed. Think I have only ever seen one.
    You really want a eaton fuller 13,or 18 speed.
    Now is you trans, overdrive, or direct drive? If its overdrive, a trans swap will not gain you much more than the ability to split upper gears. Less rpm jump. Great for on road. A eaton fuller 15 speed will give you gears splits on the low side. Great for off road. Still not gonna gain alot in top gear. 3.58's and overdrive 10 speed should have you in the high 80mph minimum. If it runs out at 60 mph, it very well could be a direct drive trans. Why idk. Or ecm could be limiting top gear rpm.
    Now I'd almost bet the truck with 2.64's has a direct drive. Not ideal for any off road work. But probably fast.
    Could be as simple as just put a 10 speed overdrive trans in truck with 3.58s.
    I run a 13 speed with 3.58s on LP24.5. Mathematically it should run 100 plus.
    beastr123 and spsauerland Thank this.
  5. sodbuster59
    12
    4
    Oct 10, 2021
    Thanks, i guess it’s back to the drawing board! :)
  6. jamespmack
    215,674
    @wore out dang it. Your post wasn't there when I posted. Guy my slow mind types slow.
    Oxbow, beastr123 and wore out Thank this.
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    You’re into a transmission change, but to get where I think you’re wanting to go you have 2 options. 15od or 8od. They both have deep-reduction so you can run high rear end ratios and still lift off heavy without destroying the truck, and their overs. Either one of those transmissions will live forever. They’re natural overs, they don’t have that box of timex parts on the back engaged all the time.
    wore out Thanks this.
  8. wore out
    15,952
    193,018
    Jun 5, 2013
    The 15 over has a final ratio of .79 while the 8LL and 9LL have .73. I personally love a 15 over. I thought I would hate it as you can’t split the last hole but with 9th being 1:1 with 3.36 rears it was just right on ol 2lane roads the big hole we saved for the super slab. On a big pull I could ease up at the bottom drop to 9th and gas it that was all I needed. It was the most forgiving easy shifting s o b I ever drove. Like the rest of the super truckers I hadda have that big 18 which took a #### and now I have a 13. There ok but sure not my ol 15
  9. Lazer
    Lazer Road Train Member
    1,790
    2,850
    Jan 22, 2017
    If the only difference between the trucks, is the rear end ratio, then change that.
