93 379 with 3406b air bubbles and pushing coolant
Discussion in 'Peterbilt Forum' started by inlinepower, Apr 1, 2015.
  1. inlinepower
    inlinepower Bobtail Member
    5
    hi new here posting for my father in law so bare with me
    he's got a 93 379 with a 3406b cat about 80k mi ago had the engine rebuilt "in frame" had new cat packs installed they said counter bores were good head was sent out freshened up came back good everything was put back together truck ran good plenty of power. 40k after rebuild put a new radiator and cap on it and it has had air bubbles since then. they did a carbon dioxide test on coolant said it was good, bypassed the air compressor still had bubbles in coolant. they then pulled the head off and the gasket was good installed a new spacer plate gasket and put back together still had air bubbles mechanic told him to run it so he has been now another 40k later it started pushing coolant and still has bubbles , he's going to try a new radiator cap on it, he's called mechanic and was told to keep running it. looking for opinions on what it could be radiator? cracked liner? cracked head? needles to say he's not happy been trucking for over 30 years and knows something is wrong.
    any help would be great thanks
  3. Gereke
    Gereke Light Load Member
    133
    123
    Mar 5, 2010
    So, according to the information you've posted..
    Bubbles in coolant didn't appear until 40k after rebuild when a new radiator cap was put on.
    Instead of trying a different new radiator cap, the engine was taken in and had time put into re checking the head gasket and having a new spacer plate gasket put on and the air compressor was bypassed....
    It wasn't until after that when the idea to try a different cap came to mind. That should have been the first thing.
    K.I.S.S
  4. inlinepower
    5
    a new radiator and radiator cap were installed 40k after rebuild. then bubbles were noticed. he was checking the coolant level and saw them day after radiator was installed. a bad cap would not put air in coolant to cause bubbles, it is now pushing coolant out of overflow so new cap is being put on to see if that is why its pushing coolant out. main question is what's causing the air bubbles in coolant?
  5. chainslingr
    chainslingr Bobtail Member
    31
    Mar 24, 2015
    Could have just not been bled out right and it's trapped air. Are they large or small bubbles. If you cap it how fast does the system pressurize?
  6. chainslingr
    31
    Mar 24, 2015
    If its pressurizing quickly BTW there's no way to really find out where the problem is without pressurizing the system and looking for internal leaks with a camera or pulling it apart
  7. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    Tried keeping the coolant level a little low? Keep us posted on the outcome.
  8. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    I assume it being a 93 it has air to air and not an after cooler? I have always noticed some bubbles in my old b model, small bubbles. As far as the cap I haven't seen a Peterbilt yet you could fill full with antifreeze and it not push it out. I leave about 2 inches below neck and ride.
    tmslogistics and Diesel Dave Thank this.
  9. inlinepower
    5
    thanks for the replies, the truck does not run hot its bled out, it has small air bubbles in it, he keeps the coolant at the correct level (about 2" down) its been fine for 40k (besides air bubbles) now it started to push coolant out the overflow last week , not sure if the cap is bad or if its building pressure for another reason. he's on the road now ill get in touch with him and find out what its doing and how fast its pressurizing.
    like I said he's been driving over 30 years so he knows when something isn't right but the mechanic says its normal.
    he move to NC last year from MA so he thought he try a local guy "that was recommended to him" to do the engine instead of the guy he been using for years up in MA who did the last rebuild and never had any issues with but he knew it was a mistake soon after the started. had a lot of problem since they did it, this is just one.
    the mechanic is fixing any issues so its not a problem its the down time that's killing him.
  10. raylittlebear
    raylittlebear Light Load Member
    My grandpas did that its caise the radiator wasnt filled right and its trying to push the air out he had to run is at high rpm all day with out cap all the way on to push the air put and let it re presurize it itself
  11. raylittlebear
    And he said he could have a small hole in his return line and its pushing air in and not letting fluid out
