94 t800 no mirror heat
Discussion in 'Kenworth Forum' started by gyayo2012, Mar 9, 2014.
  1. gyayo2012
    gyayo2012 Bobtail Member
    12
    Sep 26, 2011
    acushnet
    hey everyone im having and issue with the mirror heat im getting power to the switch it seems to be very little power tho, the solinoide is clicking but im not getting any power to the mirror or the end of the plugs, not to sure what ti make of it i chased all the wires and everything seems to be good no brakes no burns..has any one had this problem before? any help would be greatly appreciated
    Thanks
  3. rank
    rank Road Train Member
    9,918
    113,503
    Feb 11, 2010
    Both mirrors or just one? It's almost always the mirror itself that causes problems with my '98 T800. Seems like I have to replace a mirror every year. I check them with an infra red thermometer. When they are working good they approach 100 degrees.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The way you describe the solenoid well actually it's a relay is bad. The clicking you hear it's energizing the relay but the contacts are burnt/wore. Check the output at the relay. The relay should have a little pin number diagram on it.
    Pin 30 is the battery hot and when the relay energizes it continues on out pin 87 to the mirrors. Check pin 87 with the switch on and check pin 30 and report back
    Pin 86 is ground, pin 85 goes to the switch.
  5. gyayo2012
    12
    Sep 26, 2011
    acushnet
    yes the relay is what i meant.. im getting constant power to pin 85 everything else is dead switch on / off tahnks for the reply very appreciated!
