9400I Fault
Discussion in 'International Forum' started by CMCtech, Feb 20, 2013.
  1. CMCtech
    CMCtech Bobtail Member
    28
    11
    Feb 20, 2013
    I have a 07 9400I with a Cummins ISX and a fault 128 F11 sid 084, cant figure out what this is without reading from the
    ECU. Laptop failed
  3. Heavyd
    Heavyd Road Train Member
    7,808
    6,259
    Feb 4, 2009
    Loss or incorrect vehicle speed signal. Are you getting this from the LCD display? Do you have a "Check, or WARN ENG" light? Any engine problems?
  4. CMCtech
    28
    11
    Feb 20, 2013
    Yes Warning engine light and is running like crap
  5. CMCtech
    28
    11
    Feb 20, 2013
    Contacted International and they told me they cant read the codes from the dash??? I dont understand why they would even have the display show a fault if they couldnt understand the code
  6. Heavyd
    7,808
    6,259
    Feb 4, 2009
  7. CMCtech
    28
    11
    Feb 20, 2013
    Yeah I saw those post, helpful info on the first three numbers of the codes but doesnt help on the rest, I was told by International that engine codes wont show up on the LCD display. If it was the speed sensor on the tranny wouldnt the speedometer screw up? It helps to have Insite to tell you whats going on with them intead of guessing on the lcd codes
  8. Heavyd
    7,808
    6,259
    Feb 4, 2009
    I might have missed a link in my last post. Basically the LCD display for showing codes is flawed, and does not work properly is not to be used for troubleshooting. I don't know what their intension's were with it, but a proper service tool recommended for troubleshooting. The LCD display does show the wrong codes sometimes.
