'95 377 engine sensor ID
Discussion in 'Peterbilt Forum' started by JoeW, Apr 9, 2014.
  1. JoeW
    JoeW Bobtail Member
    I just got a 95 377 and discovered a broken engine sensor. The sensor is in the middle of three on the right side of the engine... can someone let me know what sensor this is? Pererbuilt 001.jpg
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    See that tag at the end of the wire should have a number on it. See if you can't read that number. The wire number can be found on the schematic.
    Probably your manifold pressure, temp and boost. Get that number and I'll find out.
    N14 right?
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    That sure looks light the right rear of a detroit to me. If it is then those are all coolant sensors. The # on the wire will be a big help.
