95 fld bad blinkers
Discussion in 'Freightliner Forum' started by cfannin1, Oct 14, 2015.
  1. cfannin1
    cfannin1 Bobtail Member
    17
    Sep 19, 2013
    Suddenly lost blinkers to truck, and of course trailer. Can hear the relay humming and have one light getting a solid dim light up. Changed out the signal stay on the column and blinker relay. No help. The replacement signal stat even makes a buddies truck blinkers work, so I know it's good. Where else do I need to look?
  3. AModelCat
    161,192
    By relay, do you mean just a standard relay or the actual flasher itself? Usually the flasher looks like a relay but is about twice as tall. Not sure about the Freightliner but some will have 2 flashers. 1 for turn and 1 for 4 ways.
  4. cfannin1
    17
    Sep 19, 2013
    I'm posting for a buddy, and he just said relay, so I assumed he meant the blinker relay. He's familiar with it, so should have known which to change. He jumped it somehow trying to test and it was smoking. Can I assume a short to ground somewhere?
  5. RSQ20
    RSQ20 Medium Load Member
    It will definitely smoke when power is shorted directly to ground..
    This type of diagnostics will cost $$ to fix, Your buddy needs to get the assistance of someone with electrical knowledge..
    He is obviously lacking in that department..
    .. Philip
  6. AModelCat
    161,192
    Smoke is definitely a direct short to ground. Did it smoke when the flasher was installed or just when he jumped it? If it only smoked when he jumped it, is it possible that maybe he jumped power directly to the ground by mistake?
  7. AModelCat
    161,192
    One bit of advice I will give from experience is if you are going to jump circuits, use an inline fuse in the jumper lead with the fuse matching the amperage of the circuit you're testing. That way you won't accidentally burn down the truck if you accidentally short power to ground.
  8. RSQ20
    A better way would be to make a jumper for the fuse socket, with a light bulb instead of a fuse...
    The brighter the light, the more of a ground, when the light is off, there is no circuit (to ground or otherwise)
    ... Philip
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    FLD's do not use a flasher, the flashing is controlled by the warning light panel, which triggers the relay on and off to flash. Most of the time it is just the relay or a bad connection, Terminals 85 and 86 on the relay will be the ones to trigger the relay. I'm pretty sure that the light bar will turn the ground on and off and the other will have constant power. If I'm wrong, 1 will have constant ground and the other will flash power. The 30 terminal on the relay should have power, the 87 is the one that powers the lights through the signal stat. So if you jump the 87 and 30 terminals, your lights should work, but not flash. That will verify if that side of the circuit is working correctly.
    If you find that you are not getting a flashing signal to the relay and you've checked the wiring, then the flashing unit in the light bar is bad, you could replace the panel ($$$) or just rewire it for a standard flasher. I have instructions on wiring it for a standard flasher at work, I can dig it up if you need it. You could find a used light bar in a junkyard, but there are a few different indicator light configurations, so make sure that the lights are the same place as what you have. I know someone who got the wrong one and his heated mirror light was is engine warning light and when he turn on the heated mirrors, the load light indicator came on.
    AModelCat Thanks this.
  10. cfannin1
    17
    Sep 19, 2013
    Thanks for the help @GrapeApe ! I haven't talked to him in a few days, so I'm not sure of the outcome yet
  11. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Here is the service bulletin on bypassing the light bar and adding a regular flasher.
    http://ww2.justanswer.com/uploads/gowest/2012-03-17_172933_fld_signals.pdf
    It also shows the wiring diagram that may help diagnosing the problem. The light bar does control the ground the the relay. So the 86 terminal should cycle ground/open to activate the relay and make the lights flash. If it doesn't, verify that you don't have a wiring problem by checking for the same thing at pin D13 on the light bar.
