95 Freightliner FLD120 Cummins M11 Turn Signal Issues
Discussion in 'Freightliner Forum' started by Nole922, May 3, 2013.
  1. Nole922
    Nole922 Bobtail Member
    9
    Hi, my turn signals and hazards quit working from one minute to the next...I replaced the steering column turn signal switch and still nothing...I noticed when I apply turn signal switch lever I hear relay switch engaging in and out but no lights work...I replaced flasher relay and still nothing...now the other day I noticed the turn signal lights worked for about 3 seconds and stopped and kept hearing relay engaging in and out...anyone might know what this issue could be?
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    if they light up in the dash then i would say to check the connection at the fire wall may be a little loose if all of the turn signals dont work also take the flasher and relay out check the plugs at the flasher see if they are loose on the pin
  4. donkeyshow72
    donkeyshow72 Light Load Member
    181
    76
    Oct 25, 2011
    Omaha, NE
    I had a similar problem and ended up replacing 4 relays, the cost I think was $45
  5. Nole922
    9
    Yea I tested all the relays and they checked out fine...from the previous posts I've read it's leading me to believe it might be a bad breaker or the light bar but leaning towards a bad breaker...sure is driving me insane...thanks for the help though.
  6. Kevinmckenzie
    Kevinmckenzie Bobtail Member
    Today
  7. Kevinmckenzie
    Today
    I need to know more about that too I have a 1995 Freightliner LD 120 I switch my truck to LED lights but when I switched it back to put a regular light bulb in it the only thing that do is it make the relay sound like it's have a shortness in it but when I pick the LED lights back in it works fine
