95 t600 tach gauge problem?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by T-800, Dec 5, 2014.
  1. T-800
    T-800 Light Load Member
    98
    45
    Sep 20, 2014
    Frankfort, IN
    95 kW with super 10 and s60. All the gauges work properly, including speedo. But the tach will just kind of sit at a spot for a while, then every once in a while will twitch and move but not be showing correct rpms. It doesn't sit at 0 when shut off, and it doesn't move when accelerating, decceling, or cruising. Sometimes it will move a little. We have put a good gauge on it and it showed the same thing. Does anyone know where the tach sensor is and how to replace it? If so I need to know fast bc it has to be fixed tomorrow morning. Thanks
  3. Inland-Pilot
    Inland-Pilot Light Load Member
    229
    135
    Jun 23, 2010
    Jackson, Ms
    It's in the bell housing to the best of my knowledge. Loosen the jam nut, turn it in till it hits the flywheel, count those turns, then back it all the way out. Put in the new one by hand, till it touches the flywheel, back it out same as the other was set at, tighten jam nut, plug and play.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If it has a tach sensor, it will be in the flywheel housing running off the flywheel teeth, they just unscrew. It may just need to be adjusted. You turn it in all the way, then back it out 3/4-1 turn and tighten the lock nut. If it doesn't have a sensor, then it uses an RPM signal from the ECM. That should be a DDEC III (or it may have been replaced with a DDEC IV).
    In either case, you need to diagnose the issue. You could have a wiring issue, bad sensor or the sensor could have come loose and backed out.
  5. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Where at on the housing should I look at?
  6. Inland-Pilot
    229
    135
    Jun 23, 2010
    Jackson, Ms
    Bottom of flywheel housing.
  7. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Oh also the odometer doesn't work. It will twich every once in a while but it doesn't work. Same problem as tach?
  8. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    If the speedo works OK, then I'd say that you have a bad speedo head.
